09-17-2012, 10:20 PM | #1 |
3 speed gasket question
I have a 3 speed in my 72 c10. The rear seal (were the small rear piece of trans bolts to main housing) is leaking like a siv. Going to replace the seal question is will I be able to just pull drive shaft out and do in the truck, or will the trans need to come out?
09-18-2012, 12:28 AM | #2 |
Re: 3 speed gasket question
IIRC it unbolts and slides back. You need to drain the fluid first and pull the speedo gear out. Emergency brake cable may be in the way a bit too.
09-18-2012, 07:55 AM | #3 |
Thats what I thought Thanks
