Old 05-20-2018, 09:52 PM   #1
Praxiss454
Praxiss454's Avatar
Rattle when going over small bumps
I have a weird rattle noise coming from the front driver's side wheel area, not sure exactly where. I hear it when I go over uneven road, like small potholes. It almost sounds like a smacking sound. Any tips on what my likely cause is, and how to diagnose? It really could be coming from anywhere under the hood, hard to pinpoint.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD
Thanks everyone for the help over the years.
Praxiss454 is offline   Reply With Quote
Old 05-20-2018, 10:51 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Rattle when going over small bumps
When that happened to me, the shock mounting stud was loose in the frame.
AcampoDave is offline   Reply With Quote
Old 05-20-2018, 11:12 PM   #3
Praxiss454
Praxiss454's Avatar
How did you track it down? I guess I could jack the truck up by the cross member and just shake the hell out of everything until something rattles.
Old 05-20-2018, 11:45 PM   #4
AcampoDave
AcampoDave's Avatar
I laid under it and looked everything over from front to back. Trailing arm bushings, ball joints, the shocks themselves... All that kind of stuff needs to be looked at every now and then. My truck is not slammed so I throw down a piece of cardboard and just slide underneath.
Old 05-21-2018, 01:06 AM   #5
Praxiss454
Praxiss454's Avatar
Well, now you've got me thinking that with the way it rattles as I'm going over small bumps in the road, its gotta be related to the front shock absorber on that side.
Old 05-21-2018, 10:22 AM   #6
62chevy302
hillbilly
62chevy302's Avatar
Do you have a front sway bar? If so does it use end links?
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 05-21-2018, 11:12 AM   #7
Robert Haas
Lowered springs tend to "talk" as they don't always seat in their respective saddles in the lower A arms.
Robert Haas is offline   Reply With Quote
Old 05-21-2018, 11:22 AM   #8
Praxiss454
Praxiss454's Avatar
To my knowledge, the truck has a stock ride height. I've been reading my maintenece manual section on front suspension and there are a bunch of checks I should make (and should have made before posting).
Old 05-21-2018, 04:27 PM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
Just reach in and grab the shock and see if the upper mount is loose. I had this same problem and is what is was. If you have a v8 it might be a bit of a pain to tighten.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-22-2018, 01:58 PM   #10
Praxiss454
Praxiss454's Avatar
Thumbs up Re: Rattle when going over small bumps
Sure enough, the upper mount is loose. Thanks for the tip!
Old 05-22-2018, 04:37 PM   #11
nsb29
nsb29's Avatar
Mine also came loose and had Wallowed out the hole in the frame after repairing the hole I added a little insurance
nsb29 is offline   Reply With Quote
Old 05-22-2018, 04:43 PM   #12
Praxiss454
Praxiss454's Avatar
Tightened it up and took it out on the road over lunch, its nice to not have the rattle. It's a little thing, but having fixed it gives me more confidence in the truck, and makes it feel more solid.
