06-09-2015, 03:59 PM | #1 |
Ever break a control arm like this?
Why do you think my arm snapped like this? I know ball joints can break but I never seen this. Good thing I was driving slow when it let go.
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help. Last edited by 70cst; 06-11-2015 at 01:12 AM. |
06-09-2015, 04:55 PM | #2 |
meowMEOWmeowMEOW
Re: Ever break a control arm like this?
I'm not used to steel sheering in a line like that! I'd usually assume it was a fluke from lowering the truck (or how bad modern roads are), but since it broke in a straight line, I'm less tempted to think that. That almost looks like it broke clean along an axis.
Were you going up a curb/egress or something? I'd think you'd have to really twist the suspension to fatigue the metal that far. Only other thought I'd have if that balljoint has been bad a while and slowly fatigued the metal around it from moving. I guess that could weaken it until it finally broke...but I've never seen that before.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
06-09-2015, 05:25 PM | #3 |
I have never seen one break like that. Pick and pull charges like $25 for them. Where in San Jose are you at?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-09-2015, 06:05 PM | #4 |
BR3W CITY - I was thinking the ball joint thing too. Luckily it happend right when I started driving and not when i hopped on the freeway.
tinydb84 - Im over in the Alum Rock area. Im going to have to give pick n pull a shot since this is my daily. I got to get her running asap. I heard that i can use the a arms past 72 just have to change the ball joint. Up to what year I can use and for new ball joints is there any to stay away from? |
06-09-2015, 06:10 PM | #5 |
I have had better luck with the pick and pull in Santa Clara.
I believe the lower ball joints are the same from 70-87. The bushings on the shaft are different though.
06-09-2015, 07:12 PM | #6 |
lower ball joint. 71-72 then 73 on up.
you can use the 1/2 ton control arms from 73+ though
1967custom |
06-10-2015, 12:17 AM | #7 |
That is bizarre. My guess would be the control arm got cracked or damaged from when that ball joint was installed.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
06-11-2015, 09:06 PM | #8 |
Is the ball joint tight? If it lost lube, it would try to flex and might have exceeded the fatigue limit of the arm at that spot. And if you add that to the possibility of damage as mentioned by BigRed76, bang.
07-08-2015, 01:30 AM | #9 |
if you look at the picture, on the a arm took a hit at one time, see how the end of the lip is bent, not sure if thats what caused the failure but..........you never know
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
