Old 03-21-2018, 11:37 PM   #801
66clow
66clow's Avatar
Re: How about some pics of Static Dropped C-10's
Originally Posted by todds66 View Post
awesome truck. Can you please share the size rims, tires and backspacing? Love to duplicate this look on my 68
Thanks! Not sure of the back spacing. I bought them used boss 338's. Pretty sure they come in a standard size. 255/35/20 and 295/40/20
66clow is offline   Reply With Quote
Old 06-22-2018, 03:01 PM   #802
dmartin00
dmartin00's Avatar
Re: static drop pics
Originally Posted by TxSqueeze View Post
Here's mine with a 5.5/7 and 20's
you have inner fender wells still?
dmartin00 is offline   Reply With Quote
Old 06-22-2018, 03:05 PM   #803
dmartin00
dmartin00's Avatar
Originally Posted by 66clow View Post
I was wondering too since I'm at 5 in the rear and it is sitting pretty low with springs. Not sure if there is a difference due to the bed. Haven't looked lately at the axle spacing underneath.
you have fender wells still?
Old 06-22-2018, 03:29 PM   #804
jkk
jkk's Avatar
Nice stance
jkk is offline   Reply With Quote
Old 06-25-2018, 12:30 AM   #805
gringoloco
A guy with a truck
gringoloco's Avatar
It is possible to run at this height with inner fenders, but you will rub on big bumps/dips
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
Ď70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Ď07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-25-2018, 12:31 AM   #806
66clow
66clow's Avatar
Yes I do, I'm down to 5 7 now
Old 10-11-2018, 10:28 AM   #807
Canadac10
Any of you guys running a 4/6 drop have issues with hitting the stops? My shop is saying if I go over a 2/3 drop on my '70 c10 longbox I am going to have issues of hitting, and a 2/3 drop in my opinion does nothing for the stance. I don't want to notch the frame if I can avoid it. A whole lot of nice looking rides on here!!!
Canadac10 is offline   Reply With Quote
Old 10-12-2018, 12:41 PM   #808
knomadd
knomadd's Avatar
I had a 3.5/5 before going with air and would notice the rear would hit the cut down bump stops on a large bump, but nothing too bad (no notch). I'd imagine you'd be hitting the bump stops pretty regular with a 6" rear drop. But that will also depend on the company you buy the springs from. Some companies will advertise a drop based on out-of-the-box height while others will advertise their drop based on a settled suspension which can take months to get there. I don't know which companies drop is out-of-the-box vs. settled though, so good luck.
I wouldn't imagine a long bed would make much difference on the drop, but I doubt a 3" or even a 4" drop would be a problem with bump stops.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-12-2018, 06:32 PM   #809
smbrouss70
smbrouss70's Avatar
It also depends on spring rates. One company's 5" spring might have a lower spring rate to allow it to compress more than another company's 6" spring that has a higher spring rate when hitting bumps, or being loaded down.
That being said, my only experience with drop springs has been with Early Classic's 6" drop springs for the rear. I cut down my bump stops with no notch and never bottomed out unless it was loaded down and I was driving like an @ss. I did add 2" lowering blocks later with a CPP bolt-in notch and it was even better then.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2012 Chevy Tahoe LT "Powdered Sugar"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-15-2019, 12:40 PM   #810
azbmwcrew
Almost ready to put the body back on! 68 c10
azbmwcrew is offline   Reply With Quote
Old 05-01-2019, 11:00 PM   #811
karl1964chevytruck
I have to say there are some great looking trucks on here, it has my head spinning on which direction I want to go now haha. Getting ready to lower my 66. Are there any drop spindles that will enable me to keep my drum brakes? Everything I find requires a disc conversion. Iím looking to do a 4/5. Thanks!
karl1964chevytruck is offline   Reply With Quote
Old 05-08-2019, 11:38 AM   #812
68Stepbed
Living The Dream
68Stepbed's Avatar
There aren't any drop spindles for drum brakes. Why not just make the disc brake swap?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-08-2019, 01:40 PM   #813
karl1964chevytruck
Well I would love to, but the lack of money holds me back. Also it really sucks since Iíve already put everything new on the front suspension, drums, wheel cylinders, pads, ball joints, tie rod ends, master cylinder, all new lines, etc. Iíve been doing some research and I think I just might do a spring kit, shocks, shock relocating brackets and sway bar for now.
Old 06-29-2019, 08:22 PM   #814
bozly
'71 work in progress. Currently at 4.5/7 drop with spindles/springs/blocks/shock relocation. Once I get new wheels and tires I have shorter springs for a 5.5/7 drop. It needs to have the driveshaft shortened a bit before I can get it back on the road.
bozly is offline   Reply With Quote
Old 07-01-2019, 12:55 PM   #815
Montierth
Montierth's Avatar
New paint and wheels. Drop spindle in front and flip kit in back with 1.5 -2 inch block
1970 GMC short fleet
Montierth is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
