Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-30-2019, 08:56 PM   #1
Funstuie
76 c10 (scottsdale) cluster wiring description/information?
Hey all
Iím trying to wire up a Dakota digital vid and Iíve hit a bit of wall with the cluster wiring. I donít know what each wire is and I canít seem to find a clear description. Iíve taken a couple of photos of the original gauge cluster wiring connector. Does anyone have a description of each number?
Funstuie is offline   Reply With Quote
Old 05-31-2019, 12:30 AM   #2
Funstuie
Re: 76 c10 (scottsdale) cluster wiring description/information?
I found some diagrams and got some of the wires worked out. But it says that the brake is both 6 + 13. Do I connect both thee to the Dakota box?
Also where is the tach/ignition?
Old 05-31-2019, 12:35 AM   #3
Funstuie
Another dumb one. The fuel is listed as 7 + 18 which I presume is because I have dual tanks. Am I right in that only one tank will be displayed now?
Old 05-31-2019, 05:58 PM   #4
Funstuie
I worked out that 13 for the brake was looped into 6 so I used that one
some research online suggests I tap into the signal wire on the fuel sender switch
Old 06-01-2019, 07:11 AM   #5
kipps
Do you still have the original cluster? If so, the best way to identify the wires is to trace out the paths on the printed circuit board. I've done that on a couple, and it's not hard.
1987 V20 truck, with a 2010 LMG 5.3, and a sm465 tranny.
kipps is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
