Old 05-04-2019, 09:46 AM   #76
geezer#99
geezer#99's Avatar
Re: Building my 283
Best way around that different shades of Chevy orange is to use ford red. Chevy orange will look dull and slightly yellow after many heat cycles. Ford red fades to bright Chevy orange.
But you’ve already painted it. Likely won’t see a huge amount of heat cycles.
Are you gonna install a heat shield under that eddy carb? You’ll need it, so easier to work it in now. And don’t forget fuel pressure. A regulator or low pressure pump might be needed.
Tell your pops to look here for Saginaw rebuild stuff.
http://www.garagemotorsports.com/muncie.htm
Old 05-07-2019, 09:27 AM   #77
Chevyrestorerman
Re: Building my 283
Just wondering if you gasket matched the intake manifold as you did for the heads.
Chevyrestorerman is offline   Reply With Quote
Old 05-07-2019, 02:58 PM   #78
OL65GMC
Re: Building my 283
I did match the intake ports as well. Nothing crazy, just opened them up to match and about an inch of blending. Also related to that I had a hell of a time getting the appearance of the intake right. I finaly used raw aluminum mag cleaner and some scotchbright. I will have to do. I'll post a pic soon.
OL65GMC is offline   Reply With Quote
Old 06-03-2019, 07:58 AM   #79
OL65GMC
Re: Building my 283
Ok, a lot of time passed since my last post. Got so involed in the build i kinda forgot i was documenting it. So since my last post there has been a lot of progress. I finished up with the assembly of the motor on the stand, had a couple of snags that I can share. First the intake manifold... After finaly getting the aluminum to look like I wanted i installed the intake, but soon realized the oil fill tube hole was too tight. Some "mild" persuasion resulted in a small piece breaking on the lip of the hole. Off it came. Cleaned it up with the die grinder and back on again. Lesson 456 on test fitting everything. Here are a few pics of before and after.
Old 06-03-2019, 08:13 AM   #80
OL65GMC
Re: Building my 283
Next was exhaust manifolds... No problems with the manifolds themselves but related alternator bracket mounting was a big hang up. I went with sone rams horns, 2 1/2 inch outlet, no accessorie holes. Combined with my earlier choice of short water pump and my options for brackets was small. Basically i had purchased an alternator bracket some time before for a long pump and didnt realize it. I knew the difference but didnt catch it till install. That bracket wouldnt work. Then i tried a generator header mount bracket and that didnt work even after modification. Began to fab up my own and then found Alan Grove's stuff and that worked fine. In hind sight i would have used a long water pump if i had thought it through better, knowing electric fan was in the future. First 3 pics of bad bracket attempts, second 3 of Alan Grove bracket.
Old 06-03-2019, 08:14 AM   #81
OL65GMC
Re: Building my 283
Pics
Old 06-03-2019, 08:25 AM   #82
OL65GMC
Re: Building my 283
In the mean time, Pops was digging in to the 4 speed. He found a great outfit in Oregon or Washington that sent him the rebuild kit and hears we needed replaced. Unfortunately I didnt think to take pics of his operation but i have this one of the case being primed. Post a pic of completed trans soon.
Old 07-13-2019, 02:26 PM   #83
AcampoDave
AcampoDave's Avatar
Re: Building my 283
So? Is it up and running?
AcampoDave is offline   Reply With Quote
Old 07-13-2019, 09:35 PM   #84
OL65GMC
Re: Building my 283
Sorry I haven't posted.. Phone took a crap and lost most of my my build pics. To answer your question yes, well it was. Rocker studs on #3 pulled so I had to pull the heads and get them machined to accept threaded studs.
Old 07-13-2019, 09:45 PM   #85
OL65GMC
Re: Building my 283
Dropping in the motor and breaking it in actually didn't go too bad. Only real hang up was having the wrong coil. The stock look hei I went with was missing instructions and I put a 3.0 ohm coil with it. Wouldn't idle. Went through a whole lot of diagnostic headache before I found out dizzy shoukd have a 0.7 ohm coil. Installed the right coil and ran like a top.
Old 07-26-2019, 09:49 PM   #86
Marty68
Re: Building my 283
great write up.. my 283 runs great at this point. intake carb and cam is on the wish list
Marty68 is offline   Reply With Quote
Old 07-29-2019, 12:56 PM   #87
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: Building my 283
Good to see a 283 Rebuild and install... Pics/Vids??? Looks Great Also..
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 07-29-2019, 05:03 PM   #88
notsolo
notsolo's Avatar
Re: Building my 283
Nice build, great engine. Had mine rebuilt 40 yrs ago, may have to do it again!
notsolo is offline   Reply With Quote
Old 07-29-2019, 06:48 PM   #89
AcampoDave
AcampoDave's Avatar
Re: Building my 283
How is it to drive around? Have you had a chance to get it broke in and and wind it up yet?
Old 07-29-2019, 09:17 PM   #90
gvw5400
gvw5400's Avatar
Re: Building my 283
GOOD JOB!
After you get some miles on it, and everything is good and fully dialed in, Please bang on it hard to redline once for me!!!
Seriously, It is nice to see someone take the path less traveled. Not every truck needs to be a LS automatic, bagged and rollin on 26" Chinese alloys.
All the best,
Dirk
gvw5400 is offline   Reply With Quote
Old 07-30-2019, 07:58 PM   #91
YoungPup1977
Re: Building my 283
When did you notice the stud pulled out of the head ?
Was this during the break in I am guessing... with all the port matching time spent on the heads, the screw in studs may have been a activity to perform but that's a after thought.. glad you found the stud pulled up out of the head and not the camshaft going flat.... That rocker noise must of got some ones attention
Got any pics of the stud pulled up and the screw in studs installed, any guide plates being considered ? Did your screw in studs go into the water jacket of the head ? How was the screw in studs installed ?
YoungPup1977 is offline   Reply With Quote
Old 08-26-2019, 03:11 PM   #92
68Gold/white
Re: Building my 283
Yo, Old,
How goes it!!!
68Gold/white is online now   Reply With Quote
Old 09-08-2019, 08:17 AM   #93
YoungPup1977
Re: Building my 283
Did you have to pull the engine out ? Did your phone crap out again ? Did you really wind her up to see what she do yet..
Old 09-09-2019, 10:04 AM   #94
67C10Step
67C10Step's Avatar
Re: Building my 283
I read this whole thread because I am trying to plan ahead - WAY ahead. I recently acquired a 1967 c10 with its original 283. The engine starts and runs like a little champ but is naturally a bit tired. It had not ran in over 10 years but wasn't too hard to get back to life.
Right now I am focusing on getting the truck in road worthy shape by rebuilding brakes, suspension, etc. At some point an engine rebuild or swap will be in order. I am heavily leaning towards what was done in this thread because I think it would be nice to still have the original engine and I don't need a 400 hp wheel burning truck. Just a nice exhaust note and the comfort to know I won't meet myself on the road every 15 minutes like I do in my 2017 gmc.
67C10Step is offline   Reply With Quote
Old 09-15-2019, 01:24 AM   #95
AcampoDave
AcampoDave's Avatar
Re: Building my 283
Lots of good 283 info archived on this site. Also on the H.A.M.B. Both were a huge help when I was planning out mine. It turned out great and its still going strong. I hope the OP's is too.
Old 10-13-2019, 09:47 PM   #96
Rusty one
Rusty one's Avatar
Re: Building my 283
Great to see another taking a path less traveled.
Rebuilding my 283 which is now a 292. Wanted to keep it old school so I went with tri power!
All assembled now... rebuilding the 2004R is next.
Rusty one is offline   Reply With Quote
Old 10-15-2019, 09:05 AM   #97
YoungPup1977
Looks like this thread fizzled out maybe start your own thread with the 200 rebuild. I am sure the 200 rebuild would be a big hit on this forum. Looking forward to it
Old 10-17-2019, 09:38 PM   #98
68Gold/white
Re: Building my 283
I hope the 283 didn't fizzle out.....
