10-05-2019, 07:59 PM | #1 |
rebuilt 235 popping through carb
I just got a rebuilt 235 running today. It is popping though the carb bad like an intake valve is open. I double checked my wires and valve adjustment. Everything seems fine and it in the correct order. It will idle but has no power and is of course missing. I did notice one of the lifters did not seem pumped up. I let all of them soak in oil for like a week before installing them. The engine has a worked head new rings and main and rod bearings.Also it has a new carb and a one wire dist. new plugs and wires.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
10-06-2019, 11:42 AM | #2 |
Re: rebuilt 235 popping through carb
Check to be sure the distributor is in the right tooth
Pulatoy |
10-06-2019, 02:58 PM | #3 |
Could the cam gear be a tooth off?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-06-2019, 08:14 PM | #4 |
When is the last time the tank was replaced or cleaned?
10-06-2019, 08:39 PM | #5 |
Check the valve adjustment.
10-07-2019, 01:31 AM | #6 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
X's 2 on the valve adjustment and recheck the timing making sure TDC is correct as well...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
10-08-2019, 09:40 AM | #7 |
A compression check could help in isolating the problem.
10-09-2019, 03:15 PM | #8 |
I concur on the compression test.....will help you determine which cylinder is affected.
Please let us know what you find! Thank you. |
10-15-2019, 08:46 PM | #9 |
I changed the lifters back to solid and readjusted the valves. Runs fine now
10-16-2019, 04:11 PM | #10 |
The very first post gave it away... lifter didnt pump up.
Originally the motor had solid lifters.... why were different lifters installed. New cam ? Just wondering...... Posted via Mobile Device |
