08-13-2017, 05:15 PM | #1 |
Looking for spark plug wire recommendation
I have a Pertronix style ignition on my 327, and I'm a little overwhelmed trying to find a good set of plug wires for it. I'd like an 8mm cut to fit set and wondered if someone could offer a dsuggestion of some good wires- preferably with 90 degree plug boots. Thanks so much. Ned
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-13-2017, 09:13 PM | #2 |
Re: Looking for spark plug wire recommendation
How do you want to run them?? When i did my sbc plug wires i would use a say 70 corvette sbc set because they ran behind the heads and under the exhaust and then come up to the plugs from under neath with 90 degree ends. The beauty of doing it this way is you can get nice stock wire holders that run along the block tucked in nicely and don't get burnt up. I've replaced gobs of burnt up wire sets because they ran on top of the hot exhaust manifolds. Stock heat shields are a must for longevity. My favorite brand was standard plus and i think taylor was good too. Good luck!!
08-15-2017, 01:50 PM | #3 |
Thank you. I am running them up along the valve covers in looms. I found out some ideas on good brands so I think I am set. Thanks!
08-15-2017, 06:20 PM | #4 |
I'd be interested in what set you buy and how you like it.
Scott 1972 C20 long-wide. 350/350, Cheyenne Super, wood bed, PS, PB, dual batteries, dual tanks, leaf springs, gauges. No significant rust. No significant paint. 1971 C10 short step. Originally a 250/3ott with no options, now a 350/4L80. I purchased it already restored; only needs about 300 little details fixed. |
08-15-2017, 06:43 PM | #5 |
Taylor SpiroPro and nothing else.
08-15-2017, 07:34 PM | #6 |
I like Taylor wires but take a look on Jegs.com or Summitracing. com They have all kinds to choose from. And another thought to consider, you mentioned you were running the wires along the valve covers in looms, I was told some time ago, to stay away from the billet enclosed wire looms. Electricity is heat and with those type of looms you trap heat. These are what I'd suggest using but this color is not the only choices you have..
https://static.summitracing.com/glob....jpg?rep=False
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 Last edited by my56chevytruck; 08-15-2017 at 07:41 PM. |
08-15-2017, 08:56 PM | #7 | |
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
