Old 08-22-2017, 10:00 AM   #1
blazer2007
spring perches on a tapered sleeve rearend ?
I came across a ford 9 in. rearend which is the same width and bolt pattern as my chev truck but the rear has tapered sleeve . Could you notch the spring perches to fit and weld them in. I,m just asking cause I don,t know how precise this has to be. Is there some room for error or does it have to be absolute perfect. I don,t really want to put new tubes on. The rear end has new gears and bearings with the right gear ratio I,ve been wanting
blazer2007 is offline   Reply With Quote
Old 08-22-2017, 05:59 PM   #2
SCOTI
SCOTI's Avatar
Re: spring perches on a tapered sleeve rearend ?
As long as the perches are square, plumb, & the gaps are not excessive, notching for the different dimensions on the axle tube should not be an issue (especially when welding them).
Do try & minimize the amount of heat soak on the tubes (cold wet rags help).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 08-23-2017, 03:14 AM   #3
andrewmp6
Tapered tubes whats that 9 inch from ?
Old 08-23-2017, 08:44 AM   #4
blazer2007
I can, t remember off hand is a Versailles or something like that,they had the chev truck bolt pattern and some were disc brakes
Old 08-23-2017, 12:32 PM   #5
tinydb84
tinydb84's Avatar
My Ford 9 has some taper on the tubes. It isn't as much as it looks when you are fitting the perches (tabs in my case) to it. Just take your time when grinding and check often. You should be fine.
David
Instagram: Tinydb84
Old 08-23-2017, 09:21 PM   #6
blazer2007
Ok thanks
Old 08-24-2017, 03:10 AM   #7
andrewmp6
If its 5x5 lug its from a big ford car,The versailles and small cars are 5x4.5 and the trucks are 5x5.5
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
