Old 07-29-2010, 07:01 PM   #1
CrashBob
CrashBob's Avatar
3/4 ton rear brake drums
Hey,
How does one remove the rear brake drums on a '67 C20 with floating axles? Do the axles have to come out?
Thanks in advance,
CrashBob
"Life is all about ass. You're either covering it,laughing it off, kicking it, kissing it, busting it or trying to get a piece of it.
CrashBob is offline   Reply With Quote
Old 07-29-2010, 07:02 PM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: 3/4 ton rear brake drums
Yes, you will need to pull the axles. Be preparred; goo will run out when you unbolt them.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 07-29-2010, 07:05 PM   #3
1987 V30
after you get the axles out, you will have a large nut to remove. Then the whole drum and hub assembly will slide off as a unit.
1987 V30 is offline   Reply With Quote
Old 07-29-2010, 08:04 PM   #4
CrashBob
CrashBob's Avatar
Thanks!!
Old 08-29-2017, 08:39 AM   #5
50bomb
50bomb's Avatar
Does anyone know if this is the same for a 1965 chevy c20? I need to redo my rear brakes and seem that the drum/hub does not want to come out. Do i need to remove the axles to simply get to the brake shoes?
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
