Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-15-2012, 01:34 AM   #1
Ornery37
1965 turn signal / brake light rewiring issue
Hi, I have spent a couple of hours searching through the forum (through electrical section and doing searches) and several electrical books and have had no luck finding my issue.
I was wondering if any one had a wiring diagram for the 64-66 chevy trucks?
I have a 1965 chevy truck with a 1966 bed (has backup lights) most of the wiring was bad or gone so have been wiring it all myself. I have been checking my work along the way. And all is good, until I hook up the turn signals and park lights.
parts used are new 14 ga wire and HD turn signal switch # 910-62860 (aftermarket turn signal switch from speedway) (original switch to the truck is damaged and missing parts)
The left taillight has 3 wires coming off of it and the right only has two. So, assumed that the 3rd wire was for ground. The turn signals work fine with that hook up, but the park lights will not come on and wires get hot. So, disconnect the 3rd wire on the left side and park lights work fine, left turn signal works fine, but the right turn signal slightly flashes both taillights.
any help is greatly appreciated
Rick
1964 long fleet bed large rear window (project)(sold)
1965 chevy short fleet large rear window bagged (project)(thinking crew cab)
1965 chevy short fleet (driver/worktruck)
1937 chevy fenderless pu (use to be daily driver)
1983 MB turbo diesel (daily)
Ornery37 is offline   Reply With Quote
Old 02-15-2012, 01:37 AM   #2
Ornery37
Re: 1965 turn signal / brake light rewiring issue
forgot that 3rd wire from the left bucked is ground to the frame and not the body.
Old 02-15-2012, 01:58 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is what I have. The first one is the engine compartment and the front end and the second is the cab and dash. The third is the rear lights.
The three wires off the left lamp are a yellow which is the left turn/brake wire and the tail light ( brown) and another brown for the license plate.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-15-2012, 02:14 AM   #4
Ornery37
Thank You VetteVet! This looks like it will help.
Old 02-15-2012, 08:10 PM   #5
Ornery37
I found it to be a ground issue with the right tail light. Found this by taking another taillight and hooking it up off the vehicle and it worked.
Old 02-15-2012, 08:41 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Poor grounds are a common issue on these old trucks. Glad you got it fixed.
VetteVet
Old 10-14-2016, 01:09 PM   #7
Bloosman
Hi ez wire issue on my 65 k10.help
Bloosman is offline   Reply With Quote
Old 10-14-2016, 03:39 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
If you would be kind enough to go back to the electrical forum and click on thread tools and click on post a new thread. Then give us the details, we can help you better.
VetteVet
Old 10-14-2016, 04:15 PM   #9
Bloosman
I bought a ez wire 21 circuit for my 65 k10.in an a.c. electrician but can't make heads or tails of directions.need help across the board.in New here and thankful I guys are here to help
Old 09-08-2017, 01:10 AM   #10
1966FLEETSIDE
1966FLEETSIDE's Avatar
I have 4 wires going to the back of my 65 1 is dark green 1 is yellow with brown stripe 1 brown and 1 is teal or lighter green any help is helpful thx
1966FLEETSIDE is offline   Reply With Quote
Old 09-08-2017, 02:32 AM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The standard colors for GM cars and trucks are.
Dark green--Right turn/brake light
Yellow-- Left turn/brake light
Brown---- Tail lights and license plate light.
Light green---Backup lights
Is this what you need?
VetteVet
Old 09-08-2017, 09:21 AM   #12
1966FLEETSIDE
Thx vettevet very helpful,except mine didn't come with backup lamps so I guess I will cap the light green wire.thx again vettevet
Old 09-08-2017, 10:16 AM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Glad to help.
VetteVet
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
