Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-16-2017, 01:49 PM   #1
chazdo2
Alternator wiring problems
I have a Delco Remy alternator. Here are the numbers on it 1101 490 120 5160 -neg. Its has a black four pin connector in the back of it with the battery post near it. Vette Vette gave me a perfect description on how to wire it. Problem the 4 wire connector pins are not labeled! The largest pin if this helps is closest to the batteryName:  IMG_0282.jpg
Size:  43.7 KB alternator hot post. [
chazdo2 is offline   Reply With Quote
Old 08-16-2017, 01:59 PM   #2
AussieinNC
Dinkum Aussie
Re: Alternator wiring problems
Scroll to the bottom of this post...
http://67-72chevytrucks.com/vboard/s...d.php?t=314935
I believe you dont need any of those small plugs connected, unless you have a charge idiot light...
The post will guide you thru it...
AussieinNC is offline   Reply With Quote
Old 08-20-2017, 11:17 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Originally Posted by chazdo2 View Post
I have a Delco Remy alternator. Here are the numbers on it 1101 490 120 5160 -neg. Its has a black four pin connector in the back of it with the battery post near it. Vette Vette gave me a perfect description on how to wire it. Problem the 4 wire connector pins are not labeled! The largest pin if this helps is closest to the batteryAttachment 1681411 alternator hot post. [
As you will see in the photos below, I really prefer to work in the regular forum rather than in PMs to help solve issues because, as I explained in our conversations, I can't post helpful pictures in PMs.
The most helpful thing for us, is to know as much detail as possible about what the problem is, and what the member has that he or she is working with. Posting pictures is very helpful in this regard.
Your pictures are of a CS style alternator and the large terminal is the S terminal, S stands for sensing. It is the end terminal of the four and they will run from left to right or right to left I.E. S F L P or P L F S. As you can see
the S terminal is on the end and the L terminal is two terminals over from it.
Just look at the pins and find the large terminal then the L terminal is two over from it. The other two are not used for 67 to 72 trucks unless you have installed the computer controlled Ls fuel injected engine.
Here are three pictures to help.
Name:  Alternator Pinout.jpg
The F terminal is sometimes called the I terminal.
If the alternator is self exciting then it will not need any wires in the plugin to the alternator however I am not aware that there is a one-wire CS style alternator. There may very well be one on the market but I would still recommend using the plugin wiring harness with the resistor soldered in the L wire.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-23-2017, 08:02 AM   #4
chazdo2
I would truly and sincerely like to thank all of you who have helped me!! I should have it done soon been very busy. This is the best website!! I am on many from jet skis to mowers tractors motorcycles and many others. The people here are so polite knowledgeable and courteous! AGAIN CANT THANK YOU ALL ENOUGH!!!!!!!!!!!!
Old 08-23-2017, 01:09 PM   #5
drfloyd
Yep. VetVette should get a member of the century award for being so forthcoming with information. I don't have my build to the point of needing his expertise yet so I genuinely look forward to his knowledge base at some point in the hopefully not too distant future.
drfloyd is offline   Reply With Quote
Old 08-23-2017, 01:10 PM   #6
drfloyd
Sorry, spelled his handle wrong but you guys get it. VetteVet.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
