Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-28-2017, 06:56 PM   #1
blazer2007
g body tach in my 78 chev truck
I got this firebird tach which fits nice in my dash and wired it free hand under the hood,hot and ground wire direct to battery and to hei ign. to see if it worked and it did. Now it doesn,t want to work hooked up to a hot wire under dash, it tries but goes back to zero.
blazer2007 is offline   Reply With Quote
Old 08-29-2017, 08:09 PM   #2
ray_mcavoy
Re: g body tach in my 78 chev truck
Exactly which "hot wire" did you hook it into under the dash? It might be worth double checking that wire to make sure it is supplying full battery voltage.
Also double check the connections in the signal wire going out to the distributor (the tach will normally read zero if it has power & ground but no signal connected).
ray_mcavoy is offline   Reply With Quote
Old 08-30-2017, 09:20 AM   #3
blazer2007
I just hooked it up to a hot wire I found with key on.
Old 08-30-2017, 10:48 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Have you tried to reconnect it to the battery like you did at first to see if it would work there.
The tach is sensitive to changes in voltage like Ray said, so you might want to find a key hot source from the fuse panel that doesn't drop the voltage.
The tach connection on the distributor might not be good, so check that as well.
There are sites on Google that describe your situation if you type in "tach works but drops to zero" you may get some hits.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-30-2017, 11:18 AM   #5
blazer2007
OK thanks, I will try these tips
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
