Old 11-08-2018, 10:28 PM   #1
justin1967
spindle question
will 73-87 spindles work on 67-72 arms . im looking to add disc brakes to my truck . i know the 71 and 72 fit but i was looking into maybe a dual piston set up off a newer square body
justin1967 is offline   Reply With Quote
Old 11-08-2018, 11:36 PM   #2
rjs53
Re: spindle question
Try this, theres info on c10-c20
http://67-72chevytrucks.com/vboard/s...d.php?t=344516
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 11-10-2018, 12:53 AM   #3
c10-72 II
Active Member
c10-72 II's Avatar
Just use the 73-87 ball joints and tie rod ends. I have 81 spindles on my 71. With these spindles I can run 91 Camaro rotors with 4 3/4 bolt pattern. I don’t have many 5x5 rims and don’t feel like buying some. Plus the frame I have was bare so I’m building it my way.
1972 GMC C2500 Tow Rig project
1972 C10 Air Bag project
1967 C10 Drag Truck project
1967 GMC Patina Special project
1968 C10 I have no clue what to do with project
1969 GMC C6500 I wish I had more money project
1986 K10 I have too many damn projects
c10-72 II is offline   Reply With Quote
Old 11-10-2018, 03:51 PM   #4
justin1967
reason i chose those years is because the qa1 coil over it that im going to do later prefers them so i was gonna kill to birds with one stone and buy the spindles and run them on my 67 arms until iv saved enough to get the kit but the drums have to go asap . also have a 12 bolt in the rear id like to covert to to disc . would it be cheaper to find another rear end from newer truck or buy new axles for this one
Old 11-10-2018, 10:33 PM   #5
c10-72 II
Active Member
c10-72 II's Avatar
Oh ok. I would stick with the 12 bolt and put axles in it. Some people may say save your money for a 9in etc. I’m on a budget and will stick with what I have. Plus I’m only making 450/500hp. I had a 72 out of high school....(37 now) built 327, th400 trans, built 12 bolt with axles auburn pro series 4 series carrier with 4.10s. Handled a lot of abuse. All about preference. Disc brake conversion kits are cheap. Also Caption Fab has brackets for disc brake conversions. I forget what components go with the conversion.
Old 11-12-2018, 09:19 AM   #6
justin1967
im also on a tight budget . the trucks been sitting for 10 plus yrs and i just wanna get it running a diving safely with little upgrades here and there and play with it as i go and break stuff . i appreciate your advice and any more your willing to share . this forum is a big help
Old 11-12-2018, 10:23 PM   #7
Rob#2
Keep the 12 bolt, you can get the Wilwood disk conversion and rebuild everything for under $900 if you shop around.
Rob#2 is offline   Reply With Quote
