Old 12-12-2014, 12:31 AM   #51
cericd
cericd's Avatar
Re: 6-lug Steel wheels for Disc brake Conversion
Notice the different taper on the left side of each wheel.
Chris
My 1970 SWB C/10 - http://67-72chevytrucks.com/vboard/s...d.php?t=534872
cericd is offline   Reply With Quote
Old 12-12-2014, 12:50 AM   #52
picklito
Fantastic pics! Thanks a 'zillion. Here's the Dexstar many of us are wondering about. It's got a large radius in that area that concerns me.
picklito is offline   Reply With Quote
Old 12-12-2014, 01:00 PM   #53
CMFT
CMFT's Avatar
I used a set of 15" steel wheels from Hotrod Hank's on my '64 and utilized a disk brake kit from CPP - no issues with fitment. There are cheaper options, but I was very pleased with HRH and the fit/finish of the wheels. They were powder-coated and were very nice, no flaws.
http://www.hotrodhanks.com/products/...roductID/14551
'58 Apache
CMFT is offline   Reply With Quote
Old 12-14-2014, 02:24 AM   #54
picklito
Thanks for the info about Hotrod Hank's. Unfortunately, it doesn't look like they sell a stock looking steelie in white.
I called Stockton Wheel Friday: $135 each + $45 each for powder coating. Youch.
Old 03-04-2015, 09:19 AM   #55
lolife99
lolife99's Avatar
Here's another set of 6-lug (1971-87) disc brake style steelies!
And he has hubcaps also.
http://columbiamo.craigslist.org/pts/4882185219.html
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 04-22-2015, 03:44 PM   #56
zach_carver
zach_carver's Avatar
I need a set of these for disc brakes. Would look great with factory caps.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO 350/350 HAWAIIAN BLUE, ALL ORIGINAL FOR NOW. 5/5" DROP, FUTURE LS1/4L80E
zach_carver is offline   Reply With Quote
Old 04-28-2015, 09:11 PM   #57
zach_carver
Has anyone tried a set of these on our pre-71 6-lug trucks?
The price seems right.
http://vintagecampers.com/viewpart.php?partID=930
Did anyone ever attempt this? Very curious with the offset being 0.
Old 06-19-2015, 11:45 PM   #58
picklito
What backspacing does that equate to?
Old 06-20-2015, 12:01 AM   #59
lolife99
lolife99's Avatar
Backspace depends on wheel WIDTH.
0 offset on a 6" wide wheel would be 3.5" backspace.
Keith
Old 06-20-2015, 12:03 AM   #60
picklito
That sounds about perfect, doesn't it?
Old 09-23-2015, 01:48 PM   #61
picklito
Those Dexstars are also available in gray. Just need to know if they'll clear discs. They obviously have only 3 nubs, but the hoop is a little more open than the OEM non-disc wheel. So tempted to order one and try it.
http://www.nueratrailerparts.com/p-3...ler-wheel.aspx
Old 10-07-2015, 09:59 PM   #62
NVS-C10
NVS-C10's Avatar
I ordered a set and here's the run down:
-Wheels clear disk brakes and fit our trucks (tried on 62 amd 63 C10)
-Powder coating is a little cheap
-Dog dish caps (64-66) don't fit (too tight to seat fully without beating the crap out of them)
Bottom line, good wheels, especially for the price, especially if you just want to run steel wheels without center caps or maybe full size hubcaps (not dog dish).
NVS-C10 is offline   Reply With Quote
Old 10-07-2015, 10:20 PM   #63
picklito
Good report. How's the fit at hub and lugs.
Pics?
Old 10-08-2015, 01:45 AM   #64
NVS-C10
NVS-C10's Avatar
Good report. Hoes the fit at hub and lugs.
Pics?
They're not hub centric like the factory steel wheels. The hub opening on these wheels is about 1/4" larger. And the lug hole openings are meant for 1/2" studs vs our 7/16" studs, but modern lug nuts will solve that.
I'll try and snap a pic this weekend...
Old 10-16-2015, 03:09 AM   #65
picklito
Thanks, would like to see a pic.
Old 10-16-2015, 12:43 PM   #66
runpasthefence
Active Member
runpasthefence's Avatar
I've got some for sale that are non-traditional, but look pretty good if you ad a hub cap
http://67-72chevytrucks.com/vboard/s...61#post6260661
runpasthefence is offline   Reply With Quote
Old 11-10-2015, 02:20 PM   #67
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Here is what my GM 15x8, 6 lug wheels looked like painted with trim rings and baby moons.
BTW, they are for sale, link in my signature to the classifies.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-04-2015, 01:03 AM   #68
drewbert41
drewbert41's Avatar
Bringing this thread back to life.
Can someone please tell me if these wheels off an astro van will clear disc brakes? Hard to tell with the tires one em.
Also does the rust look too bad to sandblast?
drewbert41 is offline   Reply With Quote
Old 12-04-2015, 06:34 AM   #69
lolife99
lolife99's Avatar
Yes the will clear, but Astro van wheels were 5-lug.
Keith
Old 12-04-2015, 10:54 AM   #70
drewbert41
drewbert41's Avatar
Crap, thanks.
And the search continues.
Old 12-04-2015, 12:33 PM   #71
picklito
I found 4 steelies, all 15x6 6-lug 4-nub. One doesn't match the other 3. It has slightly different contour and backspacing. Here's what 3 look like:
Old 12-04-2015, 12:35 PM   #72
picklito
Here's the oddball. Different contour at the window and lug nuts, and less backspacing. So what do I have here?
Old 12-04-2015, 03:56 PM   #73
drewbert41
drewbert41's Avatar
So do people ever take the 3 nub wheels and have someone change the offset so that discs fit?
Old 12-04-2015, 04:07 PM   #74
lolife99
lolife99's Avatar
It's not the offset or backspacing that's the issue.
It's the shape of the rim.
The pre-'71 wheels don't have the necessary clearance in the area of the disc brake caliper.
Sure you could space the wheel out with spacers or have such a negative offset built into a wheel to space it away from the caliper,... but that's not what I would consider a fix.
(even though some people have gained clearance with just a 1/4" spacer)
I'd rather have the correct wheels.
Keith
Old 12-04-2015, 04:36 PM   #75
drewbert41
drewbert41's Avatar
Thanks for the answer.
My friend is going to sell me his wheels that were on his 66. He bought the truck off of a guy that works at Austin Speed Shop. Apparently the guy had the original front wheels professionally altered to fit disc brakes. Had to run a spacer on the rears to make them look the same as the front.
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
