Old 12-08-2015, 10:16 PM   #76
lolife99
lolife99's Avatar
Re: 6-lug Steel wheels for Disc brake Conversion
This is a great pic of the differences between the pre-'71 3-nub 6-lug wheels for DRUM brakes. (on the left)
And the '71-'87 4-nub DISC BRAKE 6-lug wheels.
(on the right)
Another indicator of the NON-disc brake version besides the 3-nubs,... is the raised "hump" between each lug hole on the pre-'71 wheels.
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 12-08-2015, 11:38 PM   #77
mikewoods
mikewoods's Avatar
I have a single 15x6 4 nub wheel to sell if anyone is looking. Just taking up space in my garage.
"The Mustang’s front end is problematic, get yourself a Firebird. "- Red Forman
mikewoods is offline   Reply With Quote
Old 12-09-2015, 01:06 AM   #78
picklito
Can anybody answer my question in post #72?
picklito is offline   Reply With Quote
Old 12-11-2015, 08:53 PM   #79
mikewoods
mikewoods's Avatar
I don't know for sure, but it could be as simple as different suppliers. Are they all the same other than the contour?
Old 12-11-2015, 09:47 PM   #80
lolife99
lolife99's Avatar
what do the front side of the two wheels look like?
Keith
Old 12-12-2015, 07:26 PM   #81
picklito
1st and 4th photos are the oddball. Has raised areas around each lug nut, but less contour at the two depressed rings just inside and outside the lug circle. Also has less backspacing. You can see how the center section is more toward the rear of the wheel, not level with the drop section of the rim. In the 2nd and 3rd photos (the 3 rims that match) you can see that the center section is level with the drop center of the rim. All are 4 nub.
Old 12-12-2015, 07:51 PM   #82
lolife99
lolife99's Avatar
My guess it was a different wheel supplier.
These wheels were used on 4x4 trucks from 71-87 and 71-91 4x4 suburbans and 71-91 4x4 blazers. I'm sure there could have been different companies supplying wheels to all the different GM plants through out the years.
Keith
Old 12-12-2015, 08:28 PM   #83
picklito
Thanks for the info. My "oddball" looks like the one you showed in post #76 above. As long as I eventually have 4 with same backspacing I don't really care about these subtle differences. The seller had these on a 71 K10 and never noticed.
Old 04-08-2016, 08:18 PM   #84
Desert.Chevy
Desert.Chevy's Avatar
How about a picture of the wheel.
Thanks.
Desert.Chevy is offline   Reply With Quote
Old 04-13-2016, 02:22 PM   #85
AnotherWs6
AnotherWs6's Avatar
Bump it up.
AnotherWs6 is offline   Reply With Quote
Old 09-10-2017, 04:13 AM   #86
La Zona Imagery
Hi can someone tell me if these wheels will fit on '65 with disc brake conversion? thanks (I am thinking this is a 3 nub so it won't fit?)
1965 Chevy C-10 350 V8
2003 GMC Sierra Crew Cab 6.0L 4x4
La Zona Imagery is offline   Reply With Quote
Old 09-10-2017, 04:42 AM   #87
La Zona Imagery
I found these Dexstars online. These should fit over disc brakes right? It's ok to use these trailer wheels for our trucks/
https://www.etrailer.com/Tires-and-W...r/AM20514.html
Old 09-10-2017, 12:08 PM   #88
lolife99
lolife99's Avatar
No. those are the 3-nub version.
Keith
Old 09-11-2017, 07:12 PM   #89
RANDY COX
RANDY COX's Avatar
Name:  new pixs 002.jpg
Name:  Green wheels 002.jpg
Name:  Green wheels 003.jpg
Size:  68.1 KBI'm running these 16's on my 64 K-10 I had to grind alittle on the inside wheel and on caliper to clear, my truck is sitting on a 72 4x4 running gear...They came off my 48 Fleetline there not very wide wheels but are 16's...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 09-27-2017, 11:23 PM   #90
GAc10boy
GAc10boy's Avatar
Great info here! Piggybacking off of the most recent post, does anybody know if the factory GM 3 nub 16x5" steelies will work with disc brakes?
I scored a set and am hoping that the extra diameter will do the trick. Thanks!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB Light Green LS Build
GAc10boy is offline   Reply With Quote
Old 10-02-2017, 10:26 AM   #91
GAc10boy
GAc10boy's Avatar
Regarding my post above, factory GM 16" steel nub wheels will clear disc brakes. This was just confirmed by two parties in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=747283
According to the below response by BLT_gmc, the three and four nub 16s have different windows, so you need to stay with the same nub for a consistent look.
From BLT_gmc:
"I have been told the 3 and 4 nub rule for disc brakes clearance only applies to the 15" rims. 3 or 4 nub 16" rims will clear the disc brakes, pick either 3 or 4 and have them all the same as the cut-outs on the centers are different. Bruce"
Bluek5 also has pictures of the wheels on a disc brake set-up.
This is excellent news since I'd like to utilize a decent set of GM 16x5 3 nub steelies on my '65 once i do a disc brake conversion. Love this site!
- Robbie
Old 11-27-2017, 07:57 PM   #92
mjs94080
mjs94080's Avatar
I know this is an old post, but are thos 15 x 8 rims still available?
mjs94080 is offline   Reply With Quote
Old 01-29-2018, 01:53 PM   #93
olrosa
olrosa's Avatar
I would like a set as well
Seth
Instagram: sethrosa11
My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225
1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802
olrosa is offline   Reply With Quote
Old 01-29-2018, 01:55 PM   #94
EchoBravoSierra
Guys, I just had some luck joining a couple of K Blazer Facebook groups and posting a wanted ad. Got a set of four 4-nub 15x6 wheels which arrived on Friday.
Just a suggestion. Good luck!
EchoBravoSierra is offline   Reply With Quote
Old 01-29-2018, 04:54 PM   #95
mjs94080
mjs94080's Avatar
rad can you post link to facebook group?
post pictures of rims...
QUOTE=EchoBravoSierra;8173190]Guys, I just had some luck joining a couple of K Blazer Facebook groups and posting a wanted ad. Got a set of four 4-nub 15x6 wheels which arrived on Friday.
Just a suggestion. Good luck![/QUOTE]
Old 01-29-2018, 05:07 PM   #96
EchoBravoSierra
Just search K Blazer and check out whatever groups come up. I joined two, and go no replies in one, and two replies in the other.
Wheels are basically the same as these posted on page 1 of this thread.
Old 02-25-2018, 06:01 PM   #97
gringoloco
A guy with a truck
gringoloco's Avatar
FYI- Wheel Vintiques now offers their OE style wheel in 6-lug. Problem solved!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-25-2018, 06:51 PM   #98
cericd
cericd's Avatar
and because I'll bet the next comment would be "which Wheel Vintiques are those exactly?", here's a link.
Series 62 O.E. 6-lug wheels - https://www.wheelvintiques.com/o-e-6...ed-finish.html
Chris
My 1970 SWB C/10 - http://67-72chevytrucks.com/vboard/s...d.php?t=534872
cericd is offline   Reply With Quote
Old 02-25-2018, 07:19 PM   #99
lolife99
lolife99's Avatar
And available in:
15x5
15x7
15x8
15x10
Keith
Old 02-28-2018, 05:45 PM   #100
EchoBravoSierra
I called WV a couple months ago to ask about those. They asked for a few basic measurements of the rotor and caliper (CPP kit), then told me that those wouldn't work, that I'd need 17's at least. Didn't catch the guy's name.
I ended up with some 15" '72 Blazer wheels for my project, fit fine.
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
