10-25-2013, 05:43 PM | #1 |
Skyjacker softride new springs squeak
Not many miles at all on these new springs and the drivers rear set are squeaky as a mutha. I sprayed them down with WD to figure out the area where squeak was coming from. I'm wondering if there's a pad or something missing from this particular spring pack? I looked at the others but they all look the same.
10-25-2013, 05:59 PM | #2 |
Re: Skyjacker softride new springs squeak
were your spring bushings greased up before install?
weird you have squeakyness, my skyjackers have never made noise. maybe try some teflon spring pads http://www.jackit.com/suspension-par...wear-pads.html |
10-25-2013, 06:49 PM | #3 |
What?
Are you sure it's the springs themselves?
Typically what makes the noise, is the poly bushings that make the squeaks.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
10-25-2013, 06:50 PM | #4 | |
