Old 10-26-2013, 10:01 AM   #1
yellowbomber
1968 4x4 drag link
Hello and great site! Can't believe I didn't find it long ago. I have built several 60-76 C and K trucks over the years.
I have been searching the site for some time and have seen this discussed with no final answer.
I am re-building a 1968 K-10. It is in good shape and I plan on keeping it original as possible. To that end I plan on keeping the closed knuck 44.
Has anyone found a solution to the no longer available drag link??
The tie rod ends are the same taper, so I am currently searching for a 10-11" tie rod sleeve with 3/4" threads to build one using tie rod ends.
Thank you much!
yellowbomber is offline   Reply With Quote
Old 10-27-2013, 06:42 PM   #2
maxwoof
Re: 1968 4x4 drag link
Many times I have pondered the same question. Look on rockauto.com. Tons of stuff. I looked quIckly under 85 k20, I saw 11/16, 7/8, and 1" sleeves. If you can't find the right sleeve, maybe you could fabricate an entire link using a later model assembly. I had an 85 years ago and I always thought that the set up on that truck would work on my 62.
maxwoof is offline   Reply With Quote
Old 10-27-2013, 08:00 PM   #3
obijuan
just make it. give Dan a call at ruffstuff. right now theres a 25% discount that may be applicable here.
http://www.ruffstuffspecialties.com/catalog/STEER.html
obijuan is offline   Reply With Quote
Old 10-27-2013, 09:18 PM   #4
yellowbomber
Thanks guys. No luck at Rockauto, though I have already ordered a lot of stuff with them.
I am going to go the fab route. I ordered left and right hand threaded ends and will source some DOM from a local shop.
- The tie rod end threads are 3/4"-16tpi- in case anyone uses this thread for future ref.
