Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 09-24-2015, 12:03 PM   #1
Dave K.
Dave K.'s Avatar
350 transmission question
Okay, so this isn't exactly a Chevy pickup question--actually a Jeepster but..... Ya'll have some great knowledge here so I thought id ask the question.
My brother has an all original 60s Jeepster with the V6 and 350 trans behind it. When driving it and it's cold the Jeep stalls when it stops at a light and when it's warmed up it stumbles and lurches almost like when you don't clutch a manual as you stop.
Any ideas out there? Could be applicable to our trucks I imagine! He's replaced the torque converter.
Thanks Dave
Dave K. is offline
Old 09-24-2015, 12:48 PM   #2
Mike C
Mike C's Avatar
Re: 350 transmission question
Sounds like fuel to me. I would start with the carb. Especially looking at the choke. But remember that 90% of carburetor problems are ignition...
Why would you assume this was related to the transmission right off the bat?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is offline
Old 09-24-2015, 12:51 PM   #3
Dave K.
Dave K.'s Avatar
I'm assuming because they went through the fuel system as I recall. I'll inquire and get back to the thread. Thanks
Dave K. is offline
Old 09-24-2015, 01:26 PM   #4
cleszkie
cleszkie's Avatar
Too low of a stall rpm on the torque converter? Too high of an idle rpm? Is kick down cable adjusted properly to engage only at full throttle? Vacuum leaks?
cleszkie is offline
