Old 01-09-2012, 08:09 AM   #1
Mcgwirejh
leaf spring help
i have 1997 chevy z71 how many leaf springs should i have
Mcgwirejh is offline   Reply With Quote
Old 01-11-2012, 11:42 AM   #2
thohill
Re: leaf spring help
4 I think. I have a 94 Z71, it had 4. i swapped to a 5 leaf setup.
thohill is offline   Reply With Quote
Old 01-11-2012, 01:45 PM   #3
loudnlifted88
loudnlifted88's Avatar
3 springs a a main over load heres mine with a AAL and a 1 ton overload
IM ONLY 18 AND LOVIN IT
IF MUD AINT FLYIN YOU AINT TRYIN!
1badgmc- Just think. Someone worked hard to make it look that bad.
1988 chevy stepside 305 five speed Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383945
1994 GMC ext. cab short box 350 auto Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438873
1996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build
1998 GMC K-1500 ECSB 305 auto partd truck
1999 GMC K2500 suburban 350 4x4 Dads project
1981 Corvette 350 auto Also Dads project
1989 Corvette 350 auto ^^
1998 GMC K1500 ecsb 305 auto Brothers project
loudnlifted88 is offline   Reply With Quote
Old 01-11-2012, 07:30 PM   #4
Mcgwirejh
my truck has 4 leafs springs and 1 overload so someone added leaf to my truck then
Old 01-11-2012, 07:31 PM   #5
thohill
Or just put on a set of light duty 3/4 ton springs. Thats what I did.
Old 01-11-2012, 08:15 PM   #6
Mcgwirejh
3/4 springs will fit on a 1/2 ton truck
Old 01-11-2012, 09:18 PM   #7
thohill
yep!
Old 01-11-2012, 10:16 PM   #8
Mcgwirejh
ok then i know what they did the cause my z71 has 14 bolt rear end with 5 leaf springs in it they must took the hole thing out of a 3/4 truck stuck it under my truck
Old 01-11-2012, 10:17 PM   #9
Mcgwirejh
so is this 4 or 5 leaf springs then
Old 01-11-2012, 10:26 PM   #10
thohill
I call that a 5 leaf set, But technically it is a 4+1, meaning 4 main leaves and 1 overload leaf. But yes, those are the exact same springs that I have on my 94 Z71 ECSB. From my understanding they are light duty 3/4 ton springs. the 14 bolt rear end you have certainly would support your theory.
Springs available for these trucks-
4 leaf (3+1)
5 leaf (4+1)
6 leaf (5+1)
8 leaf (7+1)
Old 01-11-2012, 10:29 PM   #11
Mcgwirejh
yeah cause i have friends that has 1998 z71 1/2 ton he has 3 leafs and 1 overload so i can carry more weight then him does that make my truck little higher in the back end with the extra leaf and healper spring
Old 01-11-2012, 10:39 PM   #12
thohill
Yeah, It does raise the truck an extra half inch if not a little higher. And you can carry more weight, but remember that your brakes are still just regular 1/2 ton brakes, so dont go overboard carrying really heavy stuff. thats why 1 ton trucks have hydraulically boosted brakes with really big drums and rotors and calipers.
Heres a handy chart that shows the thicknesses of the different spring packs and the capacities of each. http://www.generalspringkc.com/index...parent=15&pg=1
Old 01-11-2012, 10:45 PM   #13
Mcgwirejh
yeah i dont carry anything thinknig about buying new torsion bar key for the frotn to make the frotn level with the back but i dotn know how many inches would make it level
Old 01-11-2012, 10:47 PM   #14
Mcgwirejh
i know what the person did now before i bought the truck from him they took 3/4 14 bolt rear end and the springs from it stuck it under this half ton z71 shows the rear end came out of 92 3/4 would u happend to know if i would have posi with 3.73 whats the gear ratio they had for 3/4 92 model
Old 01-11-2012, 10:50 PM   #15
thohill
http://www.gmt400.com/forum/showthre...orsion+bar+key
I dunno how great an idea that is, it tends to really wreck ball joints and make the bars sag pretty fast. The proper way to lift the front is to replace the bars, but personally I wouldnt even bother with it. the trucks came stock little higher in back than in front, why not leave it be?
Old 01-11-2012, 10:52 PM   #16
thohill
They came with a couple ratios, so no way for me to tell. all that info should be on a tag on the differential.
Old 01-11-2012, 11:07 PM   #17
Mcgwirejh
i looked for the tag on the differential could not find it where would it be
Old 01-11-2012, 11:21 PM   #18
bloertcher
bloertcher's Avatar
Some 1/2 ton Z71 trucks came factory with a 14 bolt.
RIP Baby Jack 2-06-07
See You On The Other Side My Little Man
bloertcher is offline   Reply With Quote
Old 01-12-2012, 12:23 AM   #19
thohill
Im actually not sure.
Old 01-12-2012, 12:28 AM   #20
bwood
bwood's Avatar
A guy I worked with had a 96 like this. It was badged as a 1500 Z71, but the door sticker showed a higher GVW than a 97 Z71 1/2 ton. It had the 14 bolt and a 4L80E. The frame also seemed to show more from under the body than the 1/2 ton version. He ordered it this way, he also had a 91 8 lug 2500 that supposedly had 1 ton GVW, he special ordered this one too.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 01-12-2012, 06:50 AM   #21
Mcgwirejh
sounds bad ass my truck is 1997 z71 says z71 in the glove box in the rpo codes on the door jam it says gvw 6200lbs the guy i bought it from i think just changed the rear end and the springs out in the back cuase it has 14bolt rear end under it with 5 leafs springs and helper spring
