Old 07-20-2019, 05:25 AM   #1
KMAT
350 heads
Okay since this is my favorite site to post on but yet it's been awhile I'm looking at purchasing a set of World products Sportsman 2 heads from a guy that had them on a 355 gm dirt track race car I'm a little concerned about the pitting that I hope you can see in the picture my concern is will it be any type of an issue some feedback would be so much appreciated
KMAT is offline   Reply With Quote
Old 07-20-2019, 01:04 PM   #2
aerotest
Re: 350 heads
As long as you can mill the sealing surface should be fine. You can polish the chambers if you like. Looks like they used blasting to clean the heads. I would have them checked for cracks when getting them resurfaced.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust)
aerotest is offline   Reply With Quote
Old 07-20-2019, 02:07 PM   #3
KMAT
Re: 350 heads
Okay,thanks, milling would change cleances and raise compression, i think. I have read up a little bit on that,not sure i wont to do that, but the price for heads is a hood deal, wth rollor rockers, but no push rods guy wont $500. Hmmm what to do.
Again thanks for the input
Old 07-20-2019, 02:08 PM   #4
KMAT
Re: 350 heads
Just asking what would happen if I did not mail them down
Old 07-20-2019, 02:46 PM   #5
HO455
HO455's Avatar
Re: 350 heads
If the matting surfaces are good don't worry about the combustion chambers. It is debatable whether or not if there is any benefit to polishing combustion chambers. Especially for a street vehicle. If the price is right and your happy go for it.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 07-20-2019, 03:37 PM   #6
68Gold/white
Re: 350 heads
My biggest concern is that the heads have been on a "racing" engine. Ask if he would stand behind them after they are checked for cracks.
World product heads are made of very good iron. I'm thinking you should be OK.
Did he say what size the chambers are???
There are some scotchbrite flappers that attach to a mandrel that you could use to polish the chambers...
HO, are you a member on performance years??
68Gold/white is offline   Reply With Quote
Old 07-20-2019, 07:24 PM   #7
KMAT
Re: 350 heads
Thanks a lot for the additional input I do appreciate it the heads have 2.02, 1.94 valves, 64cc chamber, 200cc intake runners, i offered the guy 300 and a 12 pack. And we closed the deal. Now i just have to figure out push rods. He didnt have any spares.
Again really appreciate the feedback and input.!!!!
Old 07-20-2019, 07:40 PM   #8
68Gold/white
Re: 350 heads
Cool!!! Do you have dished pistons??? 64cc chambers on a 350 will have fairly high compression with flat top pistons. It can be made to work, other engine components will have to fall in line to make it happen, though...
Old 07-20-2019, 08:18 PM   #9
KMAT
Re: 350 heads
Bore 30 over flat top pistons 4 bolt block.earsons roller rockers,long tube headers,wieand stealth intake, q junk carb..I dont think ill do any porting of sorts to heads,i hear and read can to intake side but bad idea to exhaust
Old 07-20-2019, 09:23 PM   #10
aerotest
Re: 350 heads
Get a push rod checker from summit and measure the required pushrod. The wrong length can cause a lot of issues. That will be a hot little motor with that much compression.
Old 07-20-2019, 10:48 PM   #11
KMAT
Re: 350 heads
The rollers are 1.60.1 intake and 1.50.1 exhuast. And sugestions for a better carb that this q junk.
I am thinking of changing out my trans, have a 700r4 now, an dont think it will handle the horsepower
Old 07-21-2019, 02:33 PM   #12
HO455
HO455's Avatar
Re: 350 heads
[QUOTE=
HO, are you a member on performance years??[/QUOTE]
Yes, I do troll over there from time to time. I don't think I've posted anything in quite a few years. You must have been pretty deep in the archives to make this connection.
RIP Bob Parks.
Old 07-21-2019, 03:09 PM   #13
KMAT
Re: 350 heads
Once again THANK YOU for the info to those whom replied to my posts@!
Old 07-21-2019, 06:34 PM   #14
68Gold/white
Re: 350 heads
No, I've seen you post here. HO455 could only be a Pontiac...LOL
I'm an expert at nothing. I post there some, if I've been there, and done that. Thankfully Cliff still posts there. He's (LOL) done a great job of shutting off the Pontiac folks from using E-carbs...
Old 07-21-2019, 06:41 PM   #15
68Gold/white
Re: 350 heads
Your compression ratio is close to 10:1. With the correct cam you can make your combo work.
LOL, there is not a better carb than a Quadrajet. It will need to be calibrated to your engine specifically
Your quadrajet can be made to work. You need to contact Cliffshighperformance.com You need to email him. he can sell you all the parts for your carb to make it shine. His stuff isn't cheap, but is worth every penny Get his Q-Jet book!!!
Have him recommend a cam for your combo also...He is the answer man!!!
