09-22-2017, 10:58 PM | #1 |
ROAD SALT victim in Texas
I thought i had found the truck i was looking for. A 72 cheyenne super.it was a unmolested 1 owner solid blue with wood bed floor.i drove 75 miles to see it. The cab looked great inside and it fired right up. Everything worked on it.well; then i noticed a dealer emblem from minnesota . Looked under the truck and never have i seen this in texas. Everthing was rusted. You could stick your finger through the trailing arms and the frame was almost that bad.anyway the asking price was quickly cut in half but i couldnt tell him i would not give $500 for it for parts. I did not take pictures. Why do they use this stuff on roads? There has to be a better way. Anyway the search goes on.
09-22-2017, 11:54 PM | #2 |
Re: ROAD SALT victim in Texas
Some of those "salt state" trucks can be pretty rough.
I've seen a few.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
09-23-2017, 12:24 AM | #3 |
Wow, life in TX must be pretty grand....
My dad bought my truck new off the lot in 1972 and drove it as a work truck for about 10 years, most of the time in winter he rode to and from work with a friend. My truck has pretty bad rust. Front end was in bad shape. Inner fenders, passenger out fender, one grill bracket, core support: trashed. Junk. Rusted beyond repair. Cab: holes in floor. Rockers: yuck. Doors: bondo babies. Rear fenders: bondo babies again. Frame seems solid. At least one A arm is rusted through. And that was just 10 years of very limited use in winter as it is a two wheel drive and according to my dad "no matter what you did---lower tire pressure, put in bed load, use chains---you go backwards on hills." These trucks were neither designed nor protected against rust. Salt is evil (and it is, for the environment) so gravel should be used. |
09-23-2017, 01:16 AM | #4 |
we are spoiled here in SE Arizona
09-23-2017, 06:55 AM | #5 |
That's why most of the trucks I've restored are from TX & most of the trucks I've parted are from IN. That is one advantage to living in the salt region- lots of donors available with good trim and interior pieces
09-23-2017, 09:01 AM | #6 |
sounds like I should start buying up all these rolling frames I have been seeing. frames are plentiful and cheap. I gave away complete 72 frame cab and bed to the local scrapper.wish I would have kept it now.
09-23-2017, 01:00 PM | #7 | |
If I had the storage space, I'd buy an extra frame or two. |
09-23-2017, 05:33 PM | #8 |
If it's '72 and older, I save everything, lol.
09-23-2017, 05:44 PM | #9 |
09-23-2017, 05:59 PM | #10 |
Same, it's funny how when I was 18 all the original stuff on my truck wasn't cool like the perfect hub caps, camper mirrors, dealer bumper, emissions equipment and even a blue steering wheel made it to the trash. Ah years later I'm like wow I just hucked all those parts! I figure now someone or even me has a use for even the smallest things. So while I have the room might as well hang on to the old stuff because you never know what you'll drag home next.
09-23-2017, 09:36 PM | #11 | |
Roadtrip!
Get an AZ body and a MN interior and you will have a pretty decent truck!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-24-2017, 12:12 AM | #12 |
Salt and the "Rust Moths" are the reason ANY classic (72 and older) vehicle from down south (or out west) are so valuable.
I grew up in Michigan, home of the Worlds Largest Salt Mine, (under the Detroit area) where your car loan was guarenteed to outlast the undercarriage of your vehicle. I've bee in the south for over thirty years now, and would walk many miles rather than drive my truck on salty roads. |
09-24-2017, 01:25 AM | #13 |
