Old 09-12-2019, 05:55 PM   #1
Dachshund
Stock Seat Riser
The seat riser in my 47 (2) is pretty rusted and has been modified. Is there anywhere to get another, or do I need to fab something up. This is for the stock AD seat.....
Dachshund is offline   Reply With Quote
Old 09-12-2019, 06:08 PM   #2
jweb
jweb's Avatar
Re: Stock Seat Riser
Unless you know someone removing the stock riser or anyone cutting up a cab, I don't think there's an aftermarket replacement.
My dad had taken mine out in the 70's for bucket seats. I had to take a spot weld cutter and chisel to another cab that was being parted out.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 09-13-2019, 04:29 AM   #3
MiraclePieCo
MiraclePieCo's Avatar
It's very common for the S10 conversion guys to use those mid-90s C10 seats. I'll bet if you asked on the S10 Swap forum many of them would have their original seat riser laying around.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 09-13-2019, 07:47 PM   #4
mr48chev
mr48chev's Avatar
They are a bear to take out though.As Jweb said spot weld cutter and chisel. I've got some that would be free if you took one out but real expensive if I did it.
My ongoing truck projects:
Old 09-13-2019, 08:10 PM   #5
MiraclePieCo
I ran an air chisel under mine - came out surprisingly easy.
Old 09-14-2019, 12:18 AM   #6
mr48chev
mr48chev's Avatar
So did I but it didn't look too pretty. The one in my cowl donor cab would be a simple one as I have to take it out to cut across the floor anyhow. Trouble is it is buried in the shed I need to tear down.
Old 09-14-2019, 08:30 PM   #7
Dan in Pasadena
Dan in Pasadena's Avatar
I have a stock seat riser from my old '46 that I found because it didn't have one. The flange on it is a little chewed up - probably from someone else using an air chisel on it.
Too bad you're as far away as you are.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
