Old 05-31-2011, 10:05 PM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
mini starters
hey guys i lost the starter in my C10 this last weekend and want to replace it with a high torque mini starter. Who has one of the better brands of mini starters out there and what model should i get. theres so many to choose from and i have NO CLUE which one to go after. please let me know.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 06-02-2011, 11:24 AM   #2
storm9c1
*** That's interesting ***
storm9c1's Avatar
Re: mini starters
Go to your local auto parts store (ie: Advance) and order the following "over the counter" starter: For a 153 tooth flywheel and the straight bolt pattern starter, get the Corvette starter from a 1995 5.7L Corvette (Advance P/N 17124). That's if you have a 153 tooth flywheel and the straight bolt pattern starter. If you have a 168 tooth flywheel and the staggered bolt pattern starter, get the starter for a 2003 Silverado 3500 8.1L (P/N 17420). They are both Nippon-Denso style mini-starters, easy to get over the counter, and last forever, with a lifetime warranty. Usually around $118. Luckily GM stayed consistent with bolt patterns over all of those years. You can play the same games with Mopars as well, for example I stuck a modern Dodge Dakota starter (also Nippon-Denso style) on my '69 Charger. Again, Chrysler kept the same bolt and teeth pattern for 40 years. Little tricks to save you some money, get a better starter, have a lifetime warranty.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 06-02-2011, 11:34 AM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: mini starters
get your self a msd starter or mean green starter http://www.4x4connection.com/prodsearch/mean-green.htm
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-02-2011, 12:35 PM   #4
cdowns
cdowns's Avatar
Re: mini starters
i've used speedway motors branded starters for many years not ever a problem with any that i've used
chrome starters seem to start best
Old 06-03-2011, 06:59 AM   #5
Chevypoor
Chevypoor's Avatar
Re: mini starters
I am running a Hitachi mini starter that I purchased at Summit... had it on the truck almost two years and no problems yet.
1990 S10 Reg. cab 2wd 2.5/ 700r4, lowered, soon to be a TBI 350/ 700r4
1993 2500 Reg. cab 4wd 6.5 turbo diesel/ 5spd, bigger turbo, Bull Moose pump, cold air intake, and a few other mods
1969 C10 Reg. cab 2wd 305/350, RHS heads, Voodoo Cam, Gilmer drive, 2400 stall, and lots of other goodies!
Chevypoor is offline   Reply With Quote
Old 06-03-2011, 01:33 PM   #6
Bad70sbchevy
Bad70sbchevy's Avatar
Re: mini starters
I switched to a CVR mini starter a couple years ago in mine since I kept on having to rebuild the old gm high torque starters. Haven't had the first problem out of it.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 06-03-2011, 08:18 PM   #7
clinebarger
Re: mini starters
I 100% agree...Denso gear reduction starters are bullet-proof, Ive owned several Dodge/Cummins trucks & never replaced a starter..But I did replace the "High amp" contacts in the starter every 100K, Small price to pay for a starter on a 17 to 1 engine to last so long.
clinebarger is offline   Reply With Quote
Old 06-03-2011, 08:36 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Re: mini starters
Powermaster all the way. Made in USA, zero problems. Call their tech support line and Brady will tell you which one you need for your application.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-05-2011, 11:40 AM   #9
ProStreet83C10
Drag Racer
Re: mini starters
how would i know which flywheel i have?
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-05-2011, 02:42 PM   #10
Blue Rat
Re: mini starters
Sounds like it is time to count teeth.
Blue Rat is offline   Reply With Quote
Old 06-05-2011, 03:51 PM   #11
Lee H
Lee H's Avatar
Re: mini starters
Don't you also need special bolts for these newer starters?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-05-2011, 06:37 PM   #12
clinebarger
Re: mini starters
If the starter bolts are straight across you have a small 153 tooth flexplate.
If they are staggered you have a large 168 tooth flexplate.
Most of the time trucks use a "large" flexplate.
Old 06-05-2011, 07:39 PM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: mini starters
I have those on two of my buckets. One is 12 years old and the other is 5 years old. No issues as of yet.
one on a vortec 454 the other on my 406 sbc
KQQL IT is online now   Reply With Quote
Old 06-06-2011, 12:17 AM   #14
ProStreet83C10
Drag Racer
Re: mini starters
well heres what i went with guys.....works for both 153 and 168 tooth flywheels
http://www.jegs.com/i/CSR/170/100P/10002/-1
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-06-2011, 01:47 AM   #15
blackedoutharley
Re: mini starters
I really want to convert over to the gear reduction type starter on my '65 but have been told that it wont work with my bellhousing that current starter bolts to.
blackedoutharley is offline   Reply With Quote
Old 06-06-2011, 10:48 PM   #16
ProStreet83C10
Drag Racer
Re: mini starters
you can get OEM appearing gear reduction starters.....you just have to find the right one
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-07-2011, 03:50 AM   #17
BigDan3131
BigDan3131's Avatar
Re: mini starters
Good choice, I have one too. I had to swap to it to run a Mag on a street car. Man did I ever p*ss on every stereo guys parade driving with that on it.
BigDan3131 is offline   Reply With Quote
Old 06-07-2011, 01:54 PM   #18
storm9c1
storm9c1's Avatar
Re: mini starters
I posted this pic in another thread that I started involving my flexplate. But I wanted to follow up here about the starter. For a 168-tooth flywheel/flexplate, this starter will work perfectly on a SBC (and maybe big blocks too). Note the "L" bolt pattern that is the same for just about every SBC ever made.
186-tooth version: 8.1L 2003 Yukon or Silverado. L-pattern bolts. Advance PN 17420
153-tooth version: 5.7L 1995 Corvette. straight-pattern bolts. Advance PN 17124
Either one costs around $118 as of today with a lifetime warranty.
You might need different bolts, but so far I've been able to reuse my stock bolts on all of the 153-tooth applications that I've tried (and I've done many). YMMV.
The starter is on the left side of this pic. It is super light but packs a punch. Disregard the flexplate and other parts in the pic (was for my other post; has nothing to do with this thread).
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 06-07-2011, 11:17 PM   #19
ProStreet83C10
Drag Racer
Re: mini starters
ok guys, one last question.,..since the starter i got is for both 153 and 168 tooth flywheels does that also mean it has provisions or adapters for both staggered and straight mounting options?
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-07-2011, 11:38 PM   #20
storm9c1
storm9c1's Avatar
Re: mini starters
The universal type of starter usually has a straight bolt configuration, but with multiple holes drilled (usually 4). On the starter, if you use it on a 153-tooth, it would use one set of 2 holes. For the 168-tooth, it would need to be moved over about 3/4" outward and use the other set of 2 holes (in the starter). On the engine mount pad area, it uses the "straight" bosses for the 153 setup. Allowing you to move it sideways for either a 153 or 168 setup depending on which holes in the starter you use. It's hard to explain but once you see, it will be an "ah ha" moment.
Normally the 153 setup uses the straight row bolt pattern. And the 168 uses the L pattern on the engine pad. The universal ones just move side to side in the 153 tooth holes depending on what flywheel/flexplate you have.
Since you would have to move the starter over about 3/4" outward for a 168, there might be rare cases when it won't clear tight headers or the bellhousing cover plate hole properly, etc. YMMV. If you have a 168 and it doesn't clear something, then get a L pattern version like I posted above. But be sure you have the 3rd boss for the L pattern starter. Most motors do. But some don't.
Oh, and the gear teeth spacing is the same. Just a smaller diameter flywheel/flexplate, thus less teeth.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 03-22-2016, 06:48 PM   #21
begNOpardon
Re: mini starters
I know this is a very old post but in case someone is interested in helping I am having an issue. I upgraded to the 186-tooth version: 8.1L 2003 Yukon or Silverado. L-pattern bolts from Advance Auto Parts - PN 17420. The problem is my headers are in the way. Those of you who this worked for did you have headers or an exhaust manifold? Any ideas what would work for a '71 SBC 350 with headers?
begNOpardon is offline   Reply With Quote
Old 03-22-2016, 06:59 PM   #22
storm9c1
storm9c1's Avatar
Re: mini starters
Yeah, 17420 won't clear headers and even some stock exhaust systems. You have to try it first and be prepared to take it back.
For your application (headers), I recommend Jegs 10081 for 186-tooth flexplate/flywheels. It's the same Nippon Denso design but can be adjusted to sit closer to the pan. It's more expensive but it works great and is super strong.
http://www.jegs.com/i/JEGS+Performan...10081/10002/-1
Another option is Jegs 10080. This one can be used with both 153 and 168 tooth flexplate/flywheels. It's a little cheaper. But doesn't sit as close to the pan because you need to use the other set of holes that pushes it out. But it is more clockable, so that makes up for it. Its not as strong, but still formidable.
http://www.jegs.com/i/JEGS+Performan...10080/10002/-1
Be prepared to switch the solenoid wire ring terminal to a spade terminal with either of those starters.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 01-28-2018, 07:22 PM   #23
faun_cee
Re: mini starters
im running the OG inline 6 engine with a turbo 350 trans. will the 95' Corvette starter do just fine?
faun_cee is offline   Reply With Quote
Old 02-01-2018, 02:43 PM   #24
dave666693
dave666693's Avatar
Re: mini starters
Inline 6 starters in 67-72 are the same as the V8's
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 01-06-2021, 01:40 PM   #25
BigTopGT
Active Member
Re: mini starters
Bringing this back from the dead with a word of thanks and a question
I've got a 71 c10 with a 350/350 and what I believe to be the 168 tooth flywheel.
How does this 2003 3500 Silverado starter wire to the 71?
I know power, obviously, but what's the arrangement for the purple and yellow wires?
Pics for reference.
BigTopGT is offline   Reply With Quote
