Old 08-30-2018, 12:05 AM   #1
suburban99
suburban99's Avatar
1972 K10 Steering flexing rivets in cross member?
Hey all, my 72 K10 is flexing the crossmember rivets. I am planning on installing a steering brace but how can I tighten up the rivets?
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 08-30-2018, 09:33 AM   #2
68panelman
68panelman's Avatar
Re: 1972 K10 Steering flexing rivets in cross member?
I don't think there's a way to tighten up the rivet. Replace it with a new grade 8 bolt, make sure it has the correct shoulder and not all threads
68panelman is offline   Reply With Quote
Old 08-30-2018, 08:36 PM   #3
suburban99
suburban99's Avatar
Here’s a picture of the rivet I removed. You can see the wear marks from 46 years or turns! Hole in frame and crossmember we’re still round and a 7/16 grade 8 fit tight. Thanks for the help.
2015 Ram 4x4 1500
1997 Boxster.
Old 08-30-2018, 09:02 PM   #4
sweetk30
sweetk30's Avatar
nice to see you did 7/16 bolt .
lots of guys say its o.k. with 3/8" but thats a tad loose . the 7/16 just needs a kiss with the drill bit and fits tight .
also good idea to grab a bolt in brace to help with the loose box bolts or cracked frame or loose riviot problem . and it firms up the steering feel a bit . http://www.offroaddesign.com/catalog/steeringkit.htm
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-07-2018, 09:52 PM   #5
mike16
its important that the replacement hardware fit tight
mike16 is offline   Reply With Quote
Old 09-25-2018, 02:26 PM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
My method is a 11mm drill bit (.433), and a 7/16-20 grade 8 bolt, and red loctite. You can torque a fine thread tighter than a coarse thread.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
