10-25-2018, 10:48 PM | #1 |
1966 C-10 Shifter Boot Solved...
Installed a saginaw 4 speed in our '66 C-10. Needless to say where the shifter comes through the floor is not very flat . I had some carpet left over from the cab, so I made a box to the contour of the floor to mount the boot on. I'm happy - turned out pretty decent ......
If you don't like this pound sand ..... |
10-26-2018, 10:18 AM | #2 |
Re: 1966 C-10 Shifter Boot Solved...
Nicely done!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-27-2018, 07:31 PM | #3 |
good idea. It looks great.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
10-28-2018, 12:16 PM | #4 |
What did you make the box out of wood or metal?
11-06-2018, 09:41 PM | #5 |
Made it out of 3/4 inch oak plywood. I painted the inside of it black. Glued the carpet on with contact cement. I made one out of cardboard first to get a good idea of the shape. Used self tapping screws to attach it to the floor.
