10-30-2018, 11:30 PM | #1 |
Spark Plug Lengths - shorty's
Read lots of conflicting info on forums from past posts, so I thought I would share some details. I have some cheap Chinese headers, and they don't have the best plug clearance. Here is a photo of the different length spark plugs commonly mentioned for small block Chevys. We have:
ACDelco 41-905 Autolite 145 NGK YR5 Champion RV92YC Accel header plugs 0576S Accel are the shortest, Champion are not far behind at a lower cost. Hope this helps someone! |
10-31-2018, 12:55 AM | #2 |
Re: Spark Plug Lengths - shorty's
Thanks for the info!
11-04-2018, 11:32 AM | #3 |
A Denso u11 is just shy of 2.25" from taper to end of plug. Can you measure any one of the ones you got pictured? Just to be able to reference to what the reader has on hand.
Alex. |
11-04-2018, 12:57 PM | #4 |
I'm out of town for a while, but here's a thread with some reference.
http://nastyz28.com/threads/spark-plug-length.60539/ I believe the UR5 is the same as my YR5 at 2.072" |
11-04-2018, 07:41 PM | #5 |
Which, if any, fit your header setup?
11-04-2018, 10:48 PM | #6 |
The NGK/Champion fit everywhere but #5. It needed Accel. You can get a pretty good deal on the Accels at Advance Auto with a 25% off deal. I also have the fiberglass spark plug wire protectors.
11-05-2018, 09:23 AM | #7 |
I used the accel's on my last 2 trucks with V8s and headers, They made a huge difference in clearance. Neither engine had much mods and they ran very well also for my situation.
11-05-2018, 11:07 PM | #8 |
And here's a picture comparing two non-tapered seat plugs for older heads and aftermarket aluminum heads. Not just shorter, but smaller body diameter and wrench size, too. Great for keeping plug boots away from header tubes. That's an NGK on the left, but Bosch and others also make plugs in that same size (called "ISO").
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
11-06-2018, 06:13 PM | #9 | |
Can you share the NGK part number? I’m seeing BKR5 and an 11 under that but can’t make out the rest. Thanks! B Last edited by ilnvyb360; 11-06-2018 at 06:13 PM. Reason: Update plug# |
11-06-2018, 06:32 PM | #10 |
They are BKR5ES
B = 14mm thread K = hex size 5/8" R = resistor 5 = heat range (comparable to AC 44 or 45, as I recall) ES = standard 3/4" reach Got them 10-12 years ago, so their part number scheme may have changed since then. I have an NGK chart that shows "11" means the gap is 1.1 mm or .044". I guess that refers to the out of box gap.
11-06-2018, 07:52 PM | #11 |
Great info! Thanks MikeB!!
11-07-2018, 10:48 AM | #12 |
Here's a link to the NGK chart:
https://rb30det.com/wp-content/uploa...7/ngkchart.jpg
