10-16-2019, 04:41 PM | #1 |
Dash Lights
Replaced the old gauge lights with LED lights. Most of my lights are working except one of the ones over the temp gauge and speedometer. Any thoughts other than bad bulb?
10-16-2019, 05:06 PM | #2 |
Re: Dash Lights
I'm going to ask it even though I know you probably tryed it. Did you rotate the bulb 180. Or try a known working bulb.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
10-16-2019, 05:31 PM | #3 |
Re: Dash Lights
I havent rotated all worked when I put in the first time but will give it a shot.
10-16-2019, 10:00 PM | #4 |
Re: Dash Lights
There are only 4 gauge illumination bulbs. Other bulbs in the instrument cluster do not glow unless the warning or indicator thing they work for is causing them to come on, such as turn signal, temperature or brake warning, high beam indicator.
