10-16-2019, 08:12 PM | #1 |
Junior Member
Changing Manifolds
I have a 69 C10 short/step with an inline 250. I'm in the process of swapping the original intake/exhaust manifolds for a 4bbl Offy intake and a 12 Bolt split exhaust manifold. At both ends of the head, there are pilot pins to hold the stock exhaust manifold in the proper position while bolting it in place. My question is: Are those two pins screwed into the head or pressed in? I don't want to risk breaking one off if they're pressed in. Thanks,
Ken |
10-16-2019, 09:26 PM | #2 |
Moderator
Re: Changing Manifolds
Last two heads I did both had the pins screwed in...just use a pair of vice grips to grip the pin and undo it as if it is a bolt.
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-16-2019, 09:37 PM | #3 |
Junior Member
Thanks Aussie - That's what I wanted to hear.
Ken |
10-17-2019, 05:39 PM | #4 |
Junior Member
Aussie - I tried the vise grip suggestion and couldn't get them to turn, so I used a short pipe wrench and that did the trick. Thanks again for your response.
Ken |
10-17-2019, 06:22 PM | #5 | |
Moderator
Glad ya got em out
