Old 11-22-2019, 08:50 AM   #1
Driver_WT
Driver_WT's Avatar
Tuck In Front Bumper
What is the best way to tuck in the front bumper on my 53 Chevy 3100? Do I modify the splash pan or make a new one? I have already trimmed three inches off of each end of the front bumper, now I want it tucked in more.
Any pics of a nicely tucked front bumper?
thanks.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 11-22-2019, 09:37 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Tuck In Front Bumper
Just modify what you have or make a new one....just like your already thinking
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 11-22-2019, 10:12 AM   #3
Driver_WT
Driver_WT's Avatar
Thanks. Do most people just tuck the front bumper in to the front of the bottom of the grill, or do you go under the grill?
Old 11-22-2019, 05:41 PM   #4
mongocanfly
Personal choice I guess...I'd keep it under the grill bar, but a little in front of it
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-22-2019, 06:41 PM   #5
mr48chev
mr48chev's Avatar
Which I interpret as on the same level that it is originally but closer to the grill.
On the splash apron, I'd say that may depend on your personal skills or the skills available to you. Either cutting and welding or fabbing a new one. I don't think you will gain what you hope to by cutting and welding though and a newly fabricated one could slip below the grill as long as it cleared a tad.
I have to do pretty much the same thing with the 49 Plymouth ribbed bumpers that I am putting on mine. Right down to trimming the ends for clearance.
My ongoing truck projects:
Old 11-22-2019, 11:02 PM   #6
Driver_WT
Driver_WT's Avatar
Thank you. I do have a new splash pan, but if I cut it up, I would like it to work. Just looking for some ideas, advice and pics of what others have done to increase my own probability of success. A good friend is helping with the truck project and he is a great welder with good equipment.
Old 11-23-2019, 12:36 AM   #7
oldman3
oldman3's Avatar
I ended up cutting about 3" out of my bumper brackets (see Pic 1)
I also narrowed mine about 3" per side and welded studs to the bumper and smoothed them out (see pic 2 @3)
I made mine own splash apron to fit my bumper and then the fenders, etc.
Here's the finished product (see pic 4)
Hope this helps...Jim
oldman3 is offline   Reply With Quote
Old 11-23-2019, 12:49 AM   #8
Driver_WT
Driver_WT's Avatar
Thanks very much Jim. I have reviewed your build a number of times and have copied some things, including your trimmed and smoothed front bumper. Is your front splash pan just flat sheet metal?
Wade
Old 11-23-2019, 10:39 AM   #9
oldman3
oldman3's Avatar
Wade
Wade, thanks for checking out the build. Yes, splash pan in 1/8" flat sheet metal. I made a poster board template of the shape and size, then cut it out...Jim
Old 11-23-2019, 10:42 AM   #10
oldman3
oldman3's Avatar
Wade, forgot to add that I welded four tabs on the pan to hold in place, like the orginal one. Here's a pic...Jim
Old 11-23-2019, 10:49 AM   #11
Driver_WT
Driver_WT's Avatar
Thanks Jim. I appreciate the detail and the pics.
Wade
Old 11-23-2019, 10:54 PM   #12
my56chevytruck
my56chevytruck's Avatar
thanks.
Wade
any thoughts of cutting the width down on the bumper to begin with? Making it not as wide as they are??
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 11-23-2019, 10:58 PM   #13
Driver_WT
Driver_WT's Avatar
I have cut 3" off each end (copied from Oldman3 - Jim).
I could not make the bumper any narrower as I have put two 3.5" driving lights in the front bumper.
Old 11-24-2019, 12:36 AM   #14
oldman3
oldman3's Avatar
Always thought that would look good, if everything was shaped right, look forward to seeing this...Jim
Old 11-24-2019, 09:43 AM   #15
Driver_WT
Driver_WT's Avatar
I will post up some pics soon Jim.
Old 11-26-2019, 04:52 PM   #16
Dan in Pasadena
Dan in Pasadena's Avatar
Jim, I’d never noticed before but in the photo it looks like the bumper & splash pan are welded together and smoothed out to be one piece. Your fit must be spot on. Nice!
Too bad the Task Force trucks never came with a splash pan. I considered making some for mine but in the crush at the end I never went back to it. This thread has me thinking!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 11-26-2019, 05:22 PM   #17
mr48chev
mr48chev's Avatar
I'd just say that Oldman3 has that fit and finish thing down to the gnats patootie and raised the bar a couple of notches there. What looks like seamless is superior fit. Time and patience there rather than throwing money at it.
Old 11-26-2019, 08:18 PM   #18
oldman3
oldman3's Avatar
Thanks Dan and mr48, for the high praise. There is a small gap between bumper and splash apron, just enough to keep it from hitting each other. Dan I'm sure you can cut a pattern of what you want, put it to metal and finish. You have a beautiful truck and this addition would add to it...Jim
Old 11-27-2019, 09:00 AM   #19
Driver_WT
Driver_WT's Avatar
I thought it was welded as well. Very nice work Jim. I am hoping that my project will be at least 75% of what you have done.
Old 11-27-2019, 10:27 AM   #20
oldman3
oldman3's Avatar
Thanks Wade. I thought about welding it together, but getting it to line up with top of bumper and under grill I wasn't sure would work, so no welding. I'm sure yours will come out fine, looking forward to pics...Jim
Old 11-27-2019, 10:33 AM   #21
MD2020
MD2020's Avatar
A little off topic
Mine's a 1956 truck
I did not have a front bumper and it had a Nova front clip.
I bought a black bumper off of eba__ and cut about 6" out of the center and pushed it up against the lower grill panel, then made some bracket to hold it.
Fit's like it was suppose to be that way.
MD2020 is offline   Reply With Quote
