Old 03-17-2018, 01:39 PM   #1
PDW HOTRODS
PDW HOTRODS's Avatar
Door glass no frame?
I have a 1950 Chevy with 1 pc door glass. I am interested in using glass without the frame around the galss. Have others done this? What fuzy track did you get? The 1953 style track would be the right thickness but not long enough. Also without the frame will the glass be more prone to cracking? Thanks.
PDW HOTRODS is offline   Reply With Quote
Old 03-18-2018, 09:53 AM   #2
oldman3
oldman3's Avatar
Re: Door glass no frame?
PDW, shouldn't be a problem. I to have a 50, I'm using plane glass. Since I made mine into a roadster, glass is held in place at front and bottom, no problems with breakage...Jim
oldman3 is offline   Reply With Quote
Old 03-19-2018, 01:20 PM   #3
Jemezcrusher
I am considering doing the same thing. I know I can buy fuzzies that will fit the glass and should be able to get them longer that the onse I bought for my 55 sedan. Those were pre-curved and I think you can get them long enough, and straight.
Might be experimental
Jemezcrusher is offline   Reply With Quote
