02-18-2021, 01:27 AM | #1 |
3/4 Ton Disk Brake Swap
Complete Front Crossmember And Rear End 400.00 BO
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
02-18-2021, 01:31 AM | #2 |
Re: 3/4 Ton Disk Brake Swap
Here you go
02-18-2021, 10:19 PM | #3 |
What year is the crossmember? Consider separating the two? Already have rear end. Thanks.
02-19-2021, 06:15 PM | #4 |
1974 Yes Will Separate
02-19-2021, 11:27 PM | #5 |
03-03-2021, 07:37 PM | #6 |
So, this stuff would allow someone to swap front and rear end on say a 1966 Custom Camper or equivalent truck, and you would get the better brakes and better rear gears (assume so) but you'd have to give up stock rims. Correct?
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
03-04-2021, 02:16 AM | #7 |
Yes it Would Be a Big improvement
03-06-2021, 12:34 AM | #8 |
74 disc brake setup ?
What size rotor would that be ? Besides 6 lug ?
dont want to hear excuses, i want to hear solution(s) |
03-06-2021, 01:19 AM | #9 | |
1/2 ton Is A 6 Lugs
