03-16-2017, 10:29 PM | #26 |
Junior Member
Re: 305 engine issues
trac209,
Just a thought, you should check to make sure the vacuum advance canister will hold a vacuum. If it leaks, its bad. I once had one go bad and had the same issues as you describe. If the can leaks then you have a double dose of bad drivability and poor mileage due to the leak at high vacuum levels and no vacuum advance to help drivability. hope this helps,
Have fun, Don |
