Old 05-10-2006, 08:13 PM   #1
bigblock73
yeller
bigblock73's Avatar
Pics for CaptKaos (frame mounted battery box)
Here are the pics I promised Chris, hope it clears up any questions you might have runnin thru your head.
By the way, the cables are not secured to the battery in the pics, just mocked up while I tidy up the wiring and finish it.
bigblock73 is offline   Reply With Quote
Old 05-11-2006, 12:57 PM   #2
PHOENIX
Re: Pics for CaptKaos (frame mounted battery box)
So you can easily remove that from the bottom?
Any pictures of how that works?
Are you going to route the power cable over the frame like that, or like the ground?
Why aren't you using an Optima?
You truck looks awesome, can't wait to see it finished.
Edit:
Is rain water a concern (top and bottom)?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 05-11-2006, 01:02 PM   #3
bigblock73
yeller
bigblock73's Avatar
Eddie, the battery tray slides down (and completely out if you choose), for easy battery maintenance and removal.
The power cable will be over the frame, I have left enough slack in it so when the battery slides down it wont bind up. The power wire is actually heading towards the back of the truck, where the remote on/off switch is.
I chose a regular group 24 battery right now mainly because of price. This battery will last long enough for me to get my money out of it. I can always upgrade to an Optima...but right now I need to get the damn truck together and drive it.
Thanks for the kind words, I can't wait to see it finished either.
Chris has the same holder, and he asked me the other night if I had any pics of mine mounted...so I went out to the garage and sanpped a few for him. Mine is on the passenger side, his will be on the drivers side.
Old 05-11-2006, 01:12 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Thanks Jeff! That's what I wanted to see. Mine will actually be on the passengers side also. The truck I am currently working on may get the older tray I have, but Su will get the CCP one. It is still up in the air though...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD)
Captkaos Customs
Old 05-11-2006, 01:14 PM   #5
PHOENIX
EDIT: nevermind, he answered while I was typing.
Is there a reason hes putting it on the drivers side?
The passenger side helps balance the weight of the driver.
Does he have something on the passenger side already?
Old 05-12-2006, 12:03 AM   #6
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Very nice Jeff. How do you remove the battery once it's in place with the bed? It looks like a narrow fit with the wing nut there to loosen. Does it have some other way of securing it safely? With it being low to the ground is why I'm curious.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 05-12-2006, 12:17 AM   #7
bigblock73
yeller
bigblock73's Avatar
Brandon, the entire tray will slide out completely...all I have to do is lower it to the lowest position, unhook the cables, and slide the tray (with the battery in it), out.
In the up position, it barely hangs below the cab...about the same height as the bottom of our typical saddle tanks.
Old 05-12-2006, 01:42 AM   #8
74Chevy74
Truck looks good from what I can see! What kind of paint os on your frame? Or is it powder????
74Chevy74 is offline   Reply With Quote
Old 05-12-2006, 08:49 AM   #9
hd78glide
hd78glide's Avatar
That's pretty cool! I've never seen that before. Where did you get the tray?
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
hd78glide is offline   Reply With Quote
Old 05-12-2006, 09:06 AM   #10
bigblock73
yeller
bigblock73's Avatar
http://www.classicperform.com/tech_a...attery-Box.htm
Old 05-12-2006, 09:30 AM   #11
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Edit:
I doubt it. The stock battery location on my '37 is under the floorboard. There have been no problems with the battery being there (other than it being a PIA to get to) for the 20 years it has been in my family. The tray, stock and original, is always full of dirt, leaves and muck, so I know it gets wet.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-12-2006, 09:53 AM   #12
hd78glide
hd78glide's Avatar
How would you jump that if you ever needed a boost? Are there remote terminals for that purpose?
This will be a part of my project!
1967 GMC 1/2 ton
1972 GMC Sierra
1975 Chev 5/4 ton
1978 1/2 Harley FLH
1998 K1500 diesel
Old 05-12-2006, 10:06 AM   #13
bigblock73
yeller
bigblock73's Avatar
You can buy remote terminals, I already have them, just not sure if I will use them.
Old 05-12-2006, 12:07 PM   #14
Captkaos
Captkaos's Avatar
I am putting the remote terminals in the stock gas door location on my 6.0L truck since the tank is in the rear...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 05-12-2006, 01:06 PM   #15
bigblock73
yeller
bigblock73's Avatar
Great idea Chris.
I thought about doing mine inside the bed somewhere...but haven't given it a whole bunch of thought.
Old 02-10-2018, 11:59 AM   #16
Bpilcher72
Bpilcher72's Avatar
Captkaos are you still making this battery tray? If so how much. Did you come up for a kid to go on it?
Bpilcher72 is offline   Reply With Quote
Old 02-11-2018, 12:05 PM   #17
Captkaos
Captkaos's Avatar
I didn't make this battery tray. CCP did. The link is above, no idea if they still make it, this post is 12 years old.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 02-11-2018, 05:12 PM   #18
LuvNLife
LuvNLife's Avatar
I believe this is it. The one shown is black, but polished is available also:
https://www.speedwaymotors.com/Drop-...SABEgKb7_D_BwE
LuvNLife is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
