Old 09-19-2018, 11:17 AM   #76
cadillac_al
Re: gm create motor ?
Sometimes the keyboeard already knows the formula, or it's fat finger syndrome. Some letters just always go together.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 09-20-2018, 01:38 PM   #77
Chevyrestorerman
Originally Posted by geezer#99 View Post
There is a formula!
It does involve some ‘metric’ calculations and a couple ‘french’ translations but otherwise easy to do.
Where is ‘X’ that it marks the spot and ‘Y’ do you live there?
Sounds like a spelling bee contest turning into a algebra test.
X+Y= Who cares.
Chevyrestorerman is offline   Reply With Quote
Old 09-20-2018, 01:49 PM   #78
AnotherWs6
AnotherWs6's Avatar
Originally Posted by PGSigns View Post
I have about 45000 on mine now in the 66. Mild comp cam, super victor intake, 670 street avenger carb. I have an in tank pump with an aeromotive return style regulator. works flawless.
Jimmy
That intake is way mis-matched for your combo. What was the logic behind running such a high rpm designed single plane?
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 11-03-2018, 07:51 PM   #79
sweetk30
sweetk30's Avatar
update : info here http://67-72chevytrucks.com/vboard/s...=755514&page=4
fired up today for the first time .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-04-2018, 12:12 PM   #80
Jrainman
Jrainman's Avatar
I have been running a L 31 crate engine for a while I think almost 2 years , a couple of things to remember when ording the L-31 is that it comes in 2 versions , a 2 bolt and a 4 bolt main , the 4 bolt main version is Known as the HD L-31 Vortec. it has larger valve stems and harden seats , with 906 casting vortec heads witch are suppose to be a upgraded vortec heads . So these heads are suppose to handle the heat better . after reserching I found there was only about a $40.00 up charge to go with the HD version of the vortec, witch came stock in 3/4 and 1 ton versions, the 2 bolts came in the 1500 class. just somthing to consider when looking at purchasing a L-31 crate engine. for me it was a $40 no brainer .
Jrainman is offline   Reply With Quote
Old 11-04-2018, 12:42 PM   #81
sweetk30
sweetk30's Avatar
it was a no brainer for me . going in a k30 work truck so she got the 4 bolt .
good point tho for the cheep upgrade bang for the buck .
