01-12-2017, 12:55 AM | #1 |
Wheel Cylinder Anchor Bolt
Wow... I had it easy. I just read a thread from the guy that snapped off the anchor bolt while trying to remove it to replace his wheel cylinders. All I had to do was buy an $11 socket and use my impact gun with all it had in it to remove the anchor bolt. So... now for the question:
It's a 1970 C10 with the world's smallest brakes (fronts are 11 x 2"). The wheel cylinder has the hoop integrated into it, which the anchor bolt goes through and ultimately into the spindle. Hopefully I have painted the picture well enough (due to lack of an ACTUAL picture currently!). What is the torque spec on that anchor bolt?! Anybody know? I have a factory shop manual that tells the inch lbs torque on the smallest most insignificant hardware on the whole truck, but not that bolt! I'd like to get it tight enough, but not snap anything off putting it back together. Thanks in advance! |
01-12-2017, 02:25 AM | #2 | |
The Older Generation
Re: Wheel Cylinder Anchor Bolt
This is as close as I could find. Seems pretty high to me but I guess that could be why they are so hard to remove.... Here are some torque specs for a 1969 chevelle out of the GM chassis service manual. FRONT SUSPENSION spherical joint upper stud nut 50 ft lbs lower stud nut 80 ft lbs stud to control arm nuts (service) 25 ft lbs steering arm attaching nuts 85 ft lbs shock absorber upper shaft nut 8 ft lbs lower attachment 20 ft lbs stabilizer bar frame bracket bolts 15 ft lbs (remote but could be part of your problem) link nuts 15 ft lbs lower control arm inner pivot nuts 80 ft lbs upper control arm attaching nuts 50 ft lbs collar bolts 45 ft lbs brake anchor pin drum brakes 130 ft lbs brake anchor bolt disc brakes 120 ft lbs wheel stud nuts 65 ft lbs REAR SUSPENSION upper control arm front bushing 80 ft lbs rear bushing 80 ft lbs lower control arm front bushing 80 ft lbs rear bushing 80 ft lbs shock absorber upper 12 ft lbs lower 65 ft lbs universal joint companion flange 14 ft lbs Another site mentioned 65# but that doesn't seem like enough.... LockDoc
11-24-2018, 08:54 PM | #3 |
I know this is an old thread, but any idea where to find replacement lock washers?
11-24-2018, 10:49 PM | #4 | |
I answered your post in the other thread. LockDoc
11-25-2018, 09:32 AM | #5 |
Saw that. Appreciate the reply
11-25-2018, 09:58 AM | #6 |
Are the lock washers actually required? If so i guess i should make a couple as i was just about finished replacing my front wheel cylinders. Thanks
11-25-2018, 10:00 AM | #7 |
Maybe for spacing. At 130 foot pounds of torque, I doubt they'll walk out on their own.
But I'm OCD, and like to do things right. |
11-25-2018, 10:14 AM | #8 |
Lock washers are old school. If the nut doesn't bottom out on the stud use a permanent locktite instead of a lock washer.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-25-2018, 10:28 AM | #9 |
Its more of a bolt. I put it in for spacing. I would prefer not to use permanent locktite in case it ever needs to be removed again. 130ft lbs should hold it.
11-25-2018, 02:12 PM | #10 |
And considering it's what holds the wheel cylinder in place, there is a more than non-zero chance it will need to be removed again. Definitely agree on the non-permanent Loctite.
