Old 05-24-2010, 12:13 PM   #1
Restrorob
The One And Only !!!
Restrorob's Avatar
AC Drain ?
One of the guy's here at work has a 89 C2500 and asked me where the AC evaporator box drain is, He said he's looked all over for one but can't find it. I haven't a clue and not going to craw around under it looking.
Any of you folks know where they hid it ?
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-24-2010, 12:16 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: AC Drain ?
I saved this pic of an underdash layout for HVAC. See if it helps.
Member Nr. 2770
Old 05-24-2010, 01:07 PM   #3
clinebarger
Re: AC Drain ?
Here you go. Is water getting in the cab? If so heres a TSB on how to fix it.
Owners of some 1988-1992 C/K vehicles may comment that water leaks from the A/C evaporator drain into the passenger compartment. This condition can be encountered during A/C operation especially on days with high humidity. Under normal operation, water gathers on the bottom of the evaporator case and drains out into the engine compartment. However, in some instances, air flowing through the engine compartment can blow the water back toward the opening in the cowl for the evaporator drain. This action may allow the water to seep down into the passenger compartment. In order to repair this condition, a drain tube (P/N 22542866) should be installed on the end of the evaporator drain. This will allow the water to drain down away from the evaporator drain opening.
clinebarger is offline   Reply With Quote
Old 05-24-2010, 01:35 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: AC Drain ?
Thanks for the schematic. I saw that the pic I had didn't show it but thought it might be of some good for someone who needed it, just in case it helped them see what doesn't necessarily show.
Member Nr. 2770
Old 05-24-2010, 02:22 PM   #5
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
Re: AC Drain ?
Here's a pic IndyAnne posted of hers:
93 Yukon
89 Silverado Z71 SWB Sport
91 K 2500 Silverado "Lobuk-Worktruk"
A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO.
Gettin' old ain't for sissies.
TennesseeZ is offline   Reply With Quote
Old 05-24-2010, 06:09 PM   #6
Restrorob
Restrorob's Avatar
Re: AC Drain ?
Yep, That's what is happening.
Thanks everyone, This place !!!!
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 05-24-2010, 11:27 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: AC Drain ?
Any questions?
Member Nr. 2770
Old 11-22-2017, 08:08 AM   #8
Desy180
Re: AC Drain ?
Thanks for the info. Good review!
Desy180 is offline   Reply With Quote
