Old 07-03-2018, 11:19 AM   #1
66 Burban
66 Burban's Avatar
Bench Seat Options
I have a 69 Short Fleet missing the bench seat - I’d like to see some pictures of later seats and what they came from to help with decision about which one to use.
Remember: "When seconds count, the Police are only minutes away".
Thx,
Billy B.
66 Burban is offline   Reply With Quote
Old 07-03-2018, 09:02 PM   #2
MattG
Junior Member
MattG's Avatar
Re: Bench Seat Options
Here is mine. I just finished installing a couple of weeks ago. Have to figure out a good angle for the “in truck” pic. Brand new seat from shop4seats.com. Direct bolt in.
Matt
_____________
1967 C20
283 CID
MattG is offline   Reply With Quote
Old 07-04-2018, 11:03 AM   #3
kaycee
kaycee's Avatar
Do a search on here ,about 10 different post on this.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 07-23-2018, 09:44 AM   #4
57Suburb
57Suburb's Avatar
Sent you a PM Matt.
1972 C30 Grain Hauler, 350/400
1967 1500 GMC Stepside SWB, In Transformation Process
1967 RS/SS Camaro 350/TKO600
57Suburb is offline   Reply With Quote
Old 07-23-2018, 03:49 PM   #5
Artofdeath
Artofdeath's Avatar
How do you like them so far Matt? Nice looking seats. Surprised you went with one color? Did you not want to do the insert a different color?
Is that black or charcoal?
Artofdeath is offline   Reply With Quote
Old 07-24-2018, 06:41 PM   #6
MattG
Junior Member
MattG's Avatar
The inside of my cab is blue. The 2 different blues they offered were not close and I didn't want a 3rd color. I am going with black and blue now for the interior. Leaving all the steel blue. Going to dye my vinyl door panels black, they are pretty whomped on anyways. need to get a new steering wheel so I figure, chrome or stainless with black grip.
Matt
_____________
1967 C20
283 CID
Old 07-24-2018, 09:09 PM   #7
Artofdeath
Artofdeath's Avatar
Beautifully done Matt!
Old 07-24-2018, 09:28 PM   #8
1972RedNeck
1972RedNeck's Avatar
Personally looking for a bench out of an early 90's truck - the backs are thinner so you can gain a little leg room.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-24-2018, 10:04 PM   #9
jocko
jocko's Avatar
thanks for sharing, there's probably a lot of buddy bucket fans starting to save their pennies for these now! They look good.
Old 07-25-2018, 10:33 AM   #10
FRCvette
Matt, seat looks great in your truck. How are they comfort wise? I am thinking about placing an order.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 07-25-2018, 03:31 PM   #11
Tquillen
I used a bench seat out of a '93 Silverado, and cut the mounts to drop it two inches and angle it back slightly. I'm 6'6", so I need the clearance. It is really comfortable, and fits the truck very well.
Tquillen is offline   Reply With Quote
Old 07-26-2018, 09:22 PM   #12
MattG
Junior Member
MattG's Avatar
Firm but comfortable. Reminds me of getting a new mattress.
Matt
_____________
1967 C20
283 CID
Old 07-26-2018, 09:40 PM   #13
FRCvette
2004 SSR
2013 Silverado swb
Old 08-07-2018, 07:23 PM   #14
FRCvette
MattG I sent you a pm.
2004 SSR
2013 Silverado swb
Old 08-08-2018, 02:28 PM   #15
vweater2001
vweater2001's Avatar
Matt, would my truck have to be originally a bucket seat truck (floor) to have those seats in my 1969 C10? I like those seats and would likely get some if I can bolt on and go and not have to cut/weld in bucket seat floor to get the seats to install.
"If you aint first your last!!"
1969 GMC C1500 Stepside Shortbed - daily driver
Mando
vweater2001 is offline   Reply With Quote
Old 08-08-2018, 08:48 PM   #16
MattG
Junior Member
MattG's Avatar
My truck was originally a bench seat truck. I replaced the factory bench seat with this one. It was direct bolt in as long as you order the proper bracket/adapters for your make model and series(years). The 3 seats bolt to the rectangular frame that bolts to the brackets that use 4 of your original 8 factory threaded holes in the cab floor.
Matt
_____________
1967 C20
283 CID
Old 08-08-2018, 08:59 PM   #17
Vero67
I used a 2010 Silverado manual seat. it has storage under the center base, three cup holders, and the storage inside the center seat back. I did have to move the gas tank out of the cab. And you do sit higher. I'm 5'10" and don't hit the ceiling though.
Vero67 is offline   Reply With Quote
Old 08-09-2018, 08:12 AM   #18
D.PASSMORE
One of the First
D.PASSMORE's Avatar
They look great and fitment is spot on. Do you have a item number from the website? I would like to look at a set for my C30. Thanks
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 08-09-2018, 09:21 AM   #19
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Mine are just sitting in the cab for now, plan to modify brackets, but the early 90's seat fits great. Lots of leg room. Picked it up on FB marketplace for $125.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 08-09-2018, 08:58 PM   #20
MattG
Junior Member
MattG's Avatar
No part number but the seat is: Cobra-Low Back 40-20-40 and the Adapter Bracket/ 67-72 Chevy -GMC. If you call them up they will send you a set of swatches so you can better match the colors. Check out their site though as they have a fair amount of seat styles.
Matt
_____________
1967 C20
283 CID
Old 11-14-2018, 06:47 AM   #21
kcmarkd
kcmarkd's Avatar
Hey Matt, good looking seats. How is the seating position in comparison to the original bench? Higher? Lower? About the same?
1970 C10 CST, PS, PB, AC, patina, original, work in progress
kcmarkd is offline   Reply With Quote
Old 11-14-2018, 09:58 AM   #22
57Suburb
57Suburb's Avatar
Here's how my seats turned out.
Old 11-16-2018, 07:14 PM   #23
MattG
Junior Member
MattG's Avatar
My seat sits higher or maybe just firmer as the old bench seat was pretty worn out and broken down. But it feels good. Your seats look great. Nice color combo. Looks like they match your interior pretty well.
Matt
_____________
1967 C20
283 CID
Old 07-11-2019, 10:32 AM   #24
novice
I just installed my shop4seats seat as well. mine seem to set very high. I'm going to cut the bracket down and reinstall.
novice is offline   Reply With Quote
Old 07-11-2019, 10:38 AM   #25
57Suburb
57Suburb's Avatar
Did you order yours with the standard 4 spring or 7? I ask because I ordered the standard spring count, and feel that the seat height is just right.
