Old 05-19-2017, 11:39 AM   #1
GM man
GM man's Avatar
Inner fender help!
You guys make putting body panels together look easy, but I dropped the passenger side inner fender well down to remove my AC, and for the life of me, I can't get that thing back in there correctly. Never took the front bolts out so it's still attached up front, but the rear and middle screw holes are way off. Is there a trick (other than buying another truck??)
1972 GMC Jimmy 6.0/4L65
1972 Chevrolet long bed 1/2 ton
GM man is offline   Reply With Quote
Old 05-19-2017, 12:28 PM   #2
lks dcvn
lks dcvn's Avatar
Re: Inner fender help!
How far off are they - do none of them line up now? I've had to manhandle the inner fenders as they are not that rigid once they are not bolted up. You could always remove the fender, install the inner fender and then bolt it up to the truck...
Post up some pictures of your situation and we can try to assist.
lks dcvn is offline   Reply With Quote
Old 05-19-2017, 02:06 PM   #3
fun in dirt
fun in dirt's Avatar
Yes similar experience; they are a total pain. I ended up having to use a long piece of pipe (shovel or something else long & stout will work) with end on inner fender & side against the tire to get some leverage to push it all somewhat back in place, then use a big philips screwdriver to get a hole lined up... it takes 2 people.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 05-20-2017, 12:46 AM   #4
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
IIRC I was talking to somebody about this and the trick is to start with the Big bolt in the back and work you way around from there. You might want to loosing the front (not all the way off but loose enough to make the big bolt your starting point)
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 05-20-2017, 01:20 AM   #5
87Skier
87Skier's Avatar
That's how I did mine. It worked for my reproduction inner fender too.
You may also need to force the fender back and tighten up a few bolts to get the fender to pull back, then start another bolt.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 05-20-2017, 10:42 AM   #6
GM man
GM man's Avatar
Thanks fellas.
