11-03-2016, 11:13 PM | #26 |
Its a Truck Thing......
Re: Here goes nuthin!! Bodywork and paint!
I can share issues that I learned. I am no way a pro at painting, but I think I did a good job on my GMC.
When you start spraying make sure your air is "clean" the more filters the better in my book. I also have an air dryer so if you can get one, use it. You might want to take out all the glass and rubber to get to all the metal. I messed up and the paint got contaminated around the seal and failed. Also didnt do the drip rails correct and it failed. Wipe the metal down with a good cleaner and special towel to get rid of contamination before spraying. You will be surprised what a bare hand can do to paint. Don't try to cover the metal with one coat. In my opinion let the paint/primers dry as long as possible between coats. I can show you pics of my truck where the paint is trying to come through the clear. I have been told that base coat/clear coat is the best for a beginner to learn. Keep the gun clean after use...... I used a gun with a bigger nozzle for primer than the paint itself. Prep is key to a nice job. Again, I am no expert on painting, but if I can do it..... From a begginers view, I know what you are getting into. PM me if you want info. Your body shop is GTG, I shot mine on dirt..... http://67-72chevytrucks.com/vboard/s...d.php?t=518599 Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
11-04-2016, 10:19 AM | #27 |
Agree with notsolo, Keep it clean and WATCH, WATCH, WATCH youtube clips.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
11-04-2016, 10:11 PM | #28 |
Ok, i put an inground pool in all by myself back in 03, never seen one installed and i watched 3 video cassette tapes on installations, so i am glad to see someone else tackle something like body work
Ive owned a shop for 25 yrs, wanted to paint cars since i was 12, still at it I paid a pool guy to come and inspect my progress when it was a dirt hole, so glad i did, from what i am seeing in the pics you need to do the same, i see alot of bullseyes and generally a friendly truck when youre done painting Friendly meaning always waiving at you, if i lived close id be happy to stop by Bryan |
11-05-2016, 01:04 AM | #29 | |
11-05-2016, 06:21 AM | #30 |
Hard to explain but ill try, you dont want any hard lines from bondo to metal, you want to see the bondo make a fadin transition to the metal, iwould never fill individual dents so close, skim coat it all and sand the whole panel , even if that means skimming the entire side of box
Most people when starting out doing body work over sand bondo, get a good air board sander and once you dont have any metal islands sticking out o f the bondo use a fill and sand primer, 3 good coats and let it dry over night, use a 4 or 6 inch sand block and sand parallel to the body curves in a cross hatch 45 degree angle, sand the whole panel as even as possible, i recommend you do this twice, this should help minimize the chance of being "friendly" |
12-23-2016, 07:33 PM | #31 |
Haven't heard from you lately how did the paint job come out ?
01-03-2017, 11:56 PM | #32 | |
I got all the bodywork done last Wednesday finally, went and got some good quality primer and a nice 80 gallon compressor, a decent primer gun and went at it! Then I got sick and so did all the kids so after shooting the whole truck with primer I pulled it back in the garage and there she sits for a couple days. I did decide on a color, it's an original GM 1970 color, it's a light blue silvery color, can't remember the name (Catalina Blue??) but the tag for the paint code is out in the garage. I'll post it up tomorrow along with pictures of the bodywork and primer job! Thanks Grumpy for lightin the fire again! Matt |
01-04-2017, 01:25 PM | #33 | |
There's no such thing as Cheap AND Good. Nice work and determination by the way!
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
01-08-2017, 02:19 AM | #34 |
Thanks! I took some pictures but they go sideways for some reason if I try to post them. I'm gonna try again tomorrow.
01-08-2017, 02:21 AM | #35 | |
01-18-2018, 11:56 AM | #36 |
Any updates?
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
01-27-2018, 12:51 AM | #37 |
Updates on not only the bodywork but adjusting the valves as well. Thanks I plan on doing this myself as well so this has been really helpful. Thanks alot
Thread Tools | |
Display Modes | |
