Old 04-16-2024, 07:24 PM   #1
72c20customcamper
72c20customcamper's Avatar
Vibration 85 K20
Been dealing with a rhythmic vibration. I can definitely say it’s in the front as the vibration comes up through the steering wheel . I’ve changed the tires had them road force balanced still the same . I just changed the front shocks from Gabriel gas to KYB the ride is much nicer and the vibration is faded but still there after the test ride put new KYBs on the rear still the same . Like I said it comes and goes in a rhythmic cycle . Be smooth and the vibrate then smooth out again and repeats . I don’t think it’s a balance issue and everything is tight in the steering parts ,could the springs be shot causing it to bounce at times . Almost feels like an undulation.
The vibration is mostly felt above 60 mph but is present at lower speeds too . It’s not a bad vibration but it’s very annoying.
Anyone deal with this ?
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-17-2024, 01:42 AM   #2
Richard
Re: Vibration 85 K20
Maybe check the hubs and make sure they are fully unlocking?
Richard
Old 04-17-2024, 07:15 AM   #3
Keith Seymore
Keith Seymore's Avatar
The "undulating" is called a "Boom/Beat" in the biz.
What that means is that you have two disturbances going on, very close in frequency, such that the sine waves gradually add and subtract, giving you this variation.
Anyone who has been in high school band has likely experienced this as they have attempted to tune their instruments.
In a vehicular context normally it is something like engine firing frequency coupled with a driveline vibration.
The good new is if you can fix one vibration then the boom/beat goes away; the bad news is then you have one vibration remaining - and - if it is engine firing you can't very well make that go away.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 04-17-2024, 07:33 AM   #4
72c20customcamper
K
Guess it’s time to check all the rotating assemblies. Tires are out since it didn’t change so I need to look at the rear driveshaft and rear end front assembly doesn’t rotate with hubs unlocked . Hat made me think it’s the front is that I feel the wheel starting faintly before it gets a little more . It’s not a bad vibration just annoying.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-17-2024, 10:48 AM   #5
Shifty One
Shifty One's Avatar
My front driveshaft did this to me.
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 04-17-2024, 11:17 AM   #6
Accelo
Accelo's Avatar
Exactly where I would look. Pull the driveline and drive it without it installed. Then get back to the group with the results. A picture of the driveline would help. Is the truck lifted?
Accelo is offline   Reply With Quote
Old 04-17-2024, 06:35 PM   #7
72c20customcamper
Front shaft doesn’t rotate when it’s not in 4 wheel drive ,truck has lockouts . Truck is bone stock
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-17-2024, 06:40 PM   #8
72c20customcamper
I’ve done that
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-17-2024, 07:55 PM   #9
400/400
Is it road speed or engine speed related?
I’ve had an odd front end vibration the would come and go when a harmonic balancer came apart. The weight was free spinning around the “hub” when the rubber came apart.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 04-17-2024, 10:49 PM   #10
57taskforce
All about them K’s
57taskforce's Avatar
Lock your hubs in but don’t put the transfer case in 4x4 and see if it goes away…. Report back what you find.
I had one that did something similar few years ago that needed hub bearings. The vibration would go away(or maybe be offset?) when the hubs were locked in.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 04-18-2024, 07:42 AM   #11
72c20customcamper
Road speed . The balancer was replaced when the engine was rebuilt
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-18-2024, 07:43 AM   #12
72c20customcamper
I’ll give it a shot
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-18-2024, 09:27 AM   #13
cadillac_al
Are your slip yokes tight or sloppy?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 04-20-2024, 08:00 AM   #14
72c20customcamper
Going to pull the shaft have it balanced . I’ll Check the slip yokes too
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-20-2024, 09:14 AM   #15
72c20customcamper
Pulled the front shaft at the diff this morning . Slip yoke is free no slop ujoints in both shafts have no play . I check to see if a hub may be hung up front driveshaft spins real easy in park . This is a light 3/4 not sure if the front springs should have a reverse arch or not but the truck is level
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-20-2024, 10:11 AM   #16
57taskforce
All about them K’s
Yeah the front springs should have a negative arch from the factory.
Tyler
Old 04-21-2024, 10:48 AM   #17
cadillac_al
Seems like a lot of slip yoke showing on that rear driveshaft. That would bother my OCD too much. How much engagement does it have?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 04-21-2024, 08:04 PM   #18
72c20customcamper
I’m not sure never been apart while I’ve owned it . I have every receipt for work on this truck since new . No mention of a new driveshaft or yoke . The log book the original owner kept had everything from gas, oil changes to the engine rebuild and repaint . He also would jot down when it snowed and he used the 4 wheel drive . So I’m sure the shaft and yoke are original to the truck
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old Today, 05:10 PM   #19
72c20customcamper
Thinking it’s in the left front . I checked the tires and the left front tire is starting to feather. I’m going to rotate the tires but I don’t think it’s weight related to the tire . Since it’s done it before with regular balancing and with the road force. Going to get new rotors and try that too might have thrown a weight on the left one . I looked at the rotors right side has two barrel pin looking things pressed into the rotor vent the drivers side has none . They are originals and are getting thin anyway
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
