12-30-2013, 12:13 PM | #1 |
bagged and z'ed steering shaft
I'm looking to find the safest and best way to step my steering shaft. The front is z'ed 3 inches and I'm goin to bag it. Anybody have an good examples of what u joints to use and if you are removing the rag joint.
12-30-2013, 06:33 PM | #2 |
Re: bagged and z'ed steering shaft
I'll take a pic of mine and post it but I modified a stock astro van shaft to my 1 ton in my signature. Bare with me til tomorrow and ill post it up.
May your life be like a roll of toilet paper... Long and useful or short and crappy!!! http://67-72chevytrucks.com/vboard/s...d.php?t=584520 |
12-30-2013, 09:49 PM | #3 |
c10 Chop Artist
Do you really need to? On my 68 i just notched the arm to clear the shaft
65 c10 build http://67-72chevytrucks.com/vboard/s...d.php?t=467433 68 c10 on 22's (sold it) http://67-72chevytrucks.com/vboard/s...d.php?t=303594 |
12-30-2013, 10:03 PM | #4 |
Idk bout 1/2 ton cus my uppers are different.
12-31-2013, 10:05 AM | #5 |
12-31-2013, 10:35 AM | #6 |
Best I got only reason the old rag joint is there is because the splines are different on the astro. Keep in mind this is a rat rod so in wasn't shooting for appearance but if u want it nice get some u joints from a race shop and some DD rod and build one
12-31-2013, 10:36 AM | #7 |
Another
12-31-2013, 10:38 AM | #8 |
Also it's bagged, z'd 4", and body dropped 4" so I had to notch as well
12-31-2013, 02:37 PM | #9 |
PROJECT 7DEUCE
I bought the borgeson joints and shaft for mine...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-31-2013, 09:40 PM | #10 |
12-31-2013, 09:44 PM | #11 |
Because it has an adjustable slide built in that allows you to modify the length when fitting
