Old 01-13-2018, 11:33 AM   #1
applebmw
spark plugs info
Swapping cast iron heads for aluminum, noticed the spark plug holes have over twice the threads. What plugs do I get?
applebmw is offline   Reply With Quote
Old 01-13-2018, 02:31 PM   #2
B. W.
B. W.'s Avatar
Re: spark plugs info
What heads are you using? The info with your heads should spec. what reach plugs to use. (if they came with any!)
B. W. is offline   Reply With Quote
Old 01-13-2018, 04:53 PM   #3
applebmw
Procomp heads, I will check the specs, don't remember seeing that info, So there are different reach plugs? My guess would be the plug just clearing the heads...
Old 01-13-2018, 09:15 PM   #4
B. W.
B. W.'s Avatar
14mm x .750 reach (19 mm), 5/8 hex, gasket seat
