05-16-2013, 10:21 PM | #1 |
91 Burb suspension to 70 C10?
I have a bagged 91 Suburban, can I just swap whole control arm setup to the 70 crossmember?
05-17-2013, 06:22 AM | #2 |
Watch out for your cornhole !
Re: 91 Burb suspension to 70 C10?
Yes. It all bolts on. You'll likely need to drill out the lower control arm u bolt holes for the larger u bolts that the later suspension uses. The holes are there already of course, but earlier trucks used small diameter u bolts. Just pass a drill bit through them to open them up. Just takes a minute.
Posted via Mobile Device |
