06-24-2018, 10:04 PM | #1 |
crossover steering pitman arm
Gents,
Working on my '76 project (in my sig) and I'm using- -new 80+ steering box(o-ring fittings) from redhead. New sector I believe. -Jeep TJ pitman arm(new) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 -GM 1-ton TREs (ES2234R&L) I reamed the pitman to accept the TREs and I went to install the pitman to the box and it doesn't fit. The spline diameter of the pitman is too small for the box. The count is the same, and the 4 index teeth seem correct, just the entire broached female spline is too small by around 1/16-3/32" measured with a tape measure and compared to a stock 2wd pitman. Everything I researched said the TJ arm would fit, but it does not. I've already built all my suspension and steering around this pitman, ofcourse I should have test fit it alot sooner but o-well. Too late, time to find something else. Does anyone have any ideas on what pitman I can use that is the same size as the TJ but fits the steering box? Obviously I can ream the taper for the TRE if it isn't correct. The TJ pitman is about 1 9/16 drop and 5-15/32"(1/2") c-c. See attached snips. I appreciate any info, thanks!
1949 Chevy 3100 P/U http://67-72chevytrucks.com/vboard/s...d.php?t=302780 1976 GMC Sierra Classic C35 CCSB http://67-72chevytrucks.com/vboard/s...25#post8188825 Last edited by RADustin; 06-24-2018 at 11:19 PM. |
06-24-2018, 10:32 PM | #2 |
Re: crossover steering pitman arm
maybe thisll help..but youd need a 88-98 steering box...http://offroaddesign.com/catalog/PitmanArms.htm
I don't know about the jeep on chevy setup
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-24-2018 at 10:37 PM. |
06-24-2018, 10:42 PM | #3 |
found this also.......http://www.pirate4x4.com/forum/chevy...rms-xover.html
06-24-2018, 11:21 PM | #4 |
thanks.
Your links help me figure out the problem. The pitman I got is for manual steering. I need a power steering pitman. now to find a power steering pitman the correct sizes. Thanks!
1949 Chevy 3100 P/U http://67-72chevytrucks.com/vboard/s...d.php?t=302780 1976 GMC Sierra Classic C35 CCSB http://67-72chevytrucks.com/vboard/s...25#post8188825 |
07-24-2018, 02:58 PM | #5 |
i used a pitman arm off of a 79 ish F150 4x4
And also got a spare that would work off of a wagoneer.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
