Old 08-08-2018, 01:30 PM   #1
BiltByMe
Noticeable miss at mid-throttle
I'm running a 350 with a MSD StreetFire distributor, Weiand dual plane intake and Holley 650 double pump carb. At idle the truck runs alright but there is a very slightmiss that you can hear if listening closely. I cant blip the throttle without it bogging hard and I don't believe its a problem with my advance. Im thinking a vacuum leak at the intake since i never retorqued the bolts after my break in period of the engine. The miss is very noticeable about 2500 rpm and there is a slight lurch that I can feel while driving. I've also seen fuel stains on the outside of the intake that would indicate a leak in the top of intake manifold but I've got the carb mounting nuts well torqued on top of a new gasket so I don't know why there would be fuel there.
BiltByMe is offline   Reply With Quote
Old 08-08-2018, 05:21 PM   #2
garyd1961
Re: Noticeable miss at mid-throttle
The fuel stains may be gas boiling in the carb. You can try an insulator gasket under the carb if that's what it is.
How do you have the vacuum advance hooked up. Do you have the vacuum advance restrictor plate hooked up. If not you probably have too much timing advance.
garyd1961 is offline   Reply With Quote
Old 08-15-2018, 11:50 AM   #3
YoungPup1977
Newly rebuilt engine.... is the carb new ?
YoungPup1977 is offline   Reply With Quote
Old 08-21-2018, 09:03 PM   #4
Mike C
Mike C's Avatar
I'm a broken record with this, but most carb issues are ignition. Most likely you have a plug, a wire, the cap, maybe the rotor, etc. that is whacked. It's firing MOST of the time, or some of the time. But fix that and most likely (never say never, right?) your carb issues go away.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-18-2018, 12:26 PM   #5
BiltByMe
That's what we initially thought. I used a timing light to check that I have spark on all cylinders and it all checked out. Now I'm not positive on whether each cylinder is firing every single time it should be and I don't know the best way to check that but with the timing light on the signal was staying in constant rhythm with engine rpm.
Old 09-18-2018, 12:39 PM   #6
geezer#99
geezer#99's Avatar
Did you check your timing when you had the light on there?
geezer#99 is online now   Reply With Quote
Old 09-24-2018, 11:51 PM   #7
YoungPup1977
check the exhaust manifold for temp. see if each exhaust manifold port is the same temp....
firing order is 18436572
check to make sure you do not have 5 and 7 swapped and/or on wrong.......
I may have missed something here, but can anyone add to what has been done to this vehicle lately ? What work has been done lately ?
my 2 cents...good luck !!!
Old 09-30-2018, 11:02 PM   #8
BiltByMe
yes i did check and it was right on the money from where I had previously set it. I don't remember now exactly what it's set at off the top of my head but I do know it hadn't changed.
Old 09-30-2018, 11:15 PM   #9
geezer#99
geezer#99's Avatar
We need to know what your initial timing is.
And pics of the fuel leakage on the intake will help.
And what Cam?
Old 09-30-2018, 11:32 PM   #10
Chevyrestorerman
New engine that you just broke in ? No idea what you put the timing at and you think its a intake gasket leaking....
Good Luck !!!!! I do like the 5/7 plug wires swapped idea mentioned above.
Chevyrestorerman is offline   Reply With Quote
Old 10-01-2018, 10:51 AM   #11
Wrenchbender Ret
Try driving it with the vacuum hose to the dist. disconnected & pluged. Like Gary says, Sometimes too much advance can cause a surge at part throttle.
George
Wrenchbender Ret is offline   Reply With Quote
Old 10-09-2018, 12:00 AM   #12
Chevyrestorerman
What was the issue on this thread, so many of these threads go out to space and never resolved. Hate for someone doing a search and they read thru these threads and they go no where. i must be the only one that happens to.
Old 10-09-2018, 11:59 AM   #13
68gmsee
Active Member
68gmsee's Avatar
Nope. Happens to everyone. I see that a lot in other forums also.
I've always encouraged everyone to please post a resolution whenever possible to help others with the same problem. Doesn't matter if there wasn't a resolution or if it was something simple. It's nice to know what happened.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-14-2018, 09:44 AM   #14
Chevyrestorerman
Are you the forum cop, just wondering who is the WHO on this forum....are you the one to go to for issues ?
Old 10-14-2018, 07:18 PM   #15
68gmsee
Active Member
68gmsee's Avatar
We call them moderators. And no, I'm not a moderator. Just someone who has experienced what you mentioned above where a posted problem has no resolution.
If you have an issue about something go to the specific site and at the very bottom there should be a member moderator. You could send them a private message.
Correction... Not every forum has a moderator at the bottom. Best to click on Forums above and on the right is a column that shows the moderators.
06 Trailblazer
