Old 10-12-2018, 01:59 PM   #1
57larry
Rear end question
my 68 coil spring rear is the early one 55 1/2 inches, however the PO put 5 lug axles from a 78 chevy in it. I'm getting ready to install rear disc brakes but the axles are sticking out of the shaft about 1 1/2 inches on each side.
the rear says HA and the ratio is 14:43 (what are these ?)
do I change axles or rear end housing to a 71-72 ? thanks, Larry
57larry is offline   Reply With Quote
Old 10-12-2018, 04:34 PM   #2
sweetk30
sweetk30's Avatar
Re: Rear end question
43 divided by 14 = 3.08 gear ratio
other than that i got nothing as i like them but have not played with them before .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-12-2018, 06:39 PM   #3
57larry
thank you for the ratio
Old 10-12-2018, 11:32 PM   #4
Captainfab
60-66 Nut
All truck 12 bolts '63-'70 are 62" wide WMS to WMS. All truck 12 bolts '71-'82 are 63.5" wide WMS to WMS. It amazes me how many people thing they can just slide the '71-'82 axles into a '63-'70 housing and it will be OK. There are 5 lug conversion axles available for the '63-'70 housing. Which way to go depends on the condition of the rest of your differential and whether or not you have room for a wider differential.
Old 10-13-2018, 05:28 PM   #5
57larry
so I guess the answer to my question is to use after mart 68 5 lug axles to fit my housing
Old 10-13-2018, 11:50 PM   #6
Captainfab
60-66 Nut
Is everything else in the differential is in good condition, then yes. You need a set of aftermarket 5 lug conversion axles for the '63-'70 truck 12 bolt.
Old 10-14-2018, 07:30 PM   #7
57larry
thank you CaptainFab
why does my manual list my axle as 30 1/2 inches long and aftermart axles are listed as 30 3/4 inches?
Old 10-15-2018, 01:19 AM   #8
Captainfab
60-66 Nut
I do not know unless the aftermarket axles are just slightly longer for some reason. They are supposed to be 30-1/2" long. You might ask the manufacturer of the axles you are looking at.
Old 10-16-2018, 03:49 PM   #9
mattfranklin
mattfranklin's Avatar
This is really good info. It will save me from doing that. Sounds like I'll just have to swap the whole '72 housing into my '70 when the time comes. In the back of my mind I was hoping for a (now known to be nonexistent) shortcut. Thanks!
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 10-16-2018, 05:31 PM   #10
Bigdav160
Bigdav160's Avatar
Way back in the day I did the same. (later 5 lug axles in my early housing).
I just made spacers out of steel and grade 8 bolts to hold the backing plates on.
It worked!
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-16-2018, 06:18 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I used shorter Moser 5 lug conversion axles in the 1969 12-bolt housing in my truck. They fit perfect.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
