Old 10-10-2018, 07:24 PM   #1
z71se
Active Member
1973-1977 Dual Splined Steering Shaft Options
Guys what are the options to delete the rag joint at the steering box? I know Borgeson makes a shaft with a universal joint at the column, but what if a guy wants universal joints at both ends like the jeep shaft mod common to 79-87 C10 owners and many many other restomod setups?
77 C10 Silverado SWB - LS Swap, mechanical resto-mod
05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e
z71se is offline   Reply With Quote
Old 10-11-2018, 08:42 AM   #2
Re: 1973-1977 Dual Splined Steering Shaft Options
I have heard of folks using a 1988-96 Jeep Cherokee (XJ) Intermediate Shaft as a replacement. I think you can also get shafts from IDIDIT and Borgeson, which are pretty expensive.
1981 GMC High Sierra SWB Stepside
2006 GMC Sierra 1500 SWB W/T
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 10-11-2018, 05:04 PM   #3
z71se
Active Member
Not on the 73-78 trucks. The Cherokee shaft won't fit on the column end
Old 10-12-2018, 11:05 AM   #4
dragonball98312
dragonball98312's Avatar
Or gear box end
73 C20
07 Silverado Classic
dragonball98312 is offline   Reply With Quote
Old 10-12-2018, 11:15 AM   #5
z71se
Active Member
Originally Posted by dragonball98312 View Post
Or gear box end
Anyone know the size and spline count of the gear box? I'd like to order the Borgeson joints and make my own.
Old 10-26-2018, 03:42 PM   #6
z71se
Active Member
Guys the answer to this question is Borgeson part # 000933.
Old 11-12-2018, 02:40 AM   #7
z71se
Active Member
Pics installed as requested! Borgeson shaft part # 000933. Features a 48 spline 1" unversal joint at the column, and a 30 spline 3/4" universal joint at the box. This should be correct for 73-77 trucks before they went to the metric steering gear in 1978. I did have to cut the shaft down about 6". It does state in the Borgeson instructions that on certain trucks (I assume 2WD models) that the shaft will have to be cut down some. No problemo! Then it was primered and painted satin black. Hard to say yet since the truck is not self-propelled, but steering feels infinitely better and the new shaft is a great compliment to my rebuilt Lee Power Steering box.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
