Old 06-04-2018, 10:43 PM   #1
CRees
CRees's Avatar
Dana 44 hub
I’m in desperate need to find a wheel hub for my 67 Chevy k10, has the original Dana 45-5F front axle with drum brakes. If anyone has any ideas as to where I can find one the help would be greatly appreciated Name:  EAA41B9B-F497-4390-A33D-E61B92431FD1.jpg
CRees is offline   Reply With Quote
Old 06-06-2018, 11:36 AM   #2
50procharged
Re: Dana 44 hub
I had the same issue for my 69. Unless you can find a good used one only other option is swap to later model hub and spindle.
50procharged is offline   Reply With Quote
Old 06-08-2018, 09:10 AM   #3
Re: Dana 44 hub
All these people swapping to disc brake front ends should have the parts you need...unless they were foolish enough to scrap the rare OEM parts people will always need for restorations. I just lost out on being given some of these axles as well as Rockwell transfer cases and SM420s. There is a value in all these parts.
Old 06-08-2018, 10:21 AM   #4
CRees
CRees's Avatar
Re: Dana 44 hub
That’s the problem I’ve been having is everybody seems to be throwing this stuff away
