Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-22-2016, 05:34 PM   #26
First c10
First c10's Avatar
Re: Project "Hulk Jr"
I agree swamp rat. Orange it is.
Anyone want to see the difference between a stretched transfer case chain and a new one???? The picture is the most the old one would bend. Versus the new one in a ball.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-22-2016, 11:08 PM   #27
First c10
First c10's Avatar
Ok so transfer case is completed. Now I just have to wait for the tramnission to get back from the shop.
GO GO!!!
Old 03-22-2016, 11:11 PM   #28
First c10
First c10's Avatar
BAM!!!
GO GO!!!
Old 03-23-2016, 10:17 AM   #29
7dee2
7dee2's Avatar
Looks good, I do love chevy orange with a little bling!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 03-23-2016, 08:56 PM   #30
swamp rat
swamp rat's Avatar
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-24-2016, 12:51 AM   #31
First c10
First c10's Avatar
Tonight I started to put the late 90's serpentine kit I bought from a forum member a few years ago and never used. I pulled the rebuilt water pump out and it does not have a heater hose attachment. So before I mount it I need to find out what the correct water pump I need. Any ideas? Well the search begins. Pictures tomorrow
GO GO!!!
Old 03-26-2016, 10:54 AM   #32
First c10
First c10's Avatar
I was able to work on the front serpentine belt system. I had to order a new pulley for the non-AC bracket as it was a little rough. Nice thing about this system is if I want to add AC I just need to remove the filler bracket and replace with the AC conpressor.
Posting from my iPhone or iPad limits me to 1 picture at a time. That is stupid.
GO GO!!!
Old 03-26-2016, 10:59 AM   #33
First c10
First c10's Avatar
Pulled a few more boxes out of storage. I have these Hedman headers, the receipt read Sept 1997. I have had them longer then my 2 youngest sons. Lol.
They are for late 70' early 80's 4x4 truck as I originally bought them for my 85' k10 I used to have.
GO GO!!!
Old 03-26-2016, 11:04 AM   #34
First c10
First c10's Avatar
Had to test fit the headers and the engine mounts. I think it will work fine as long as it doesn't hit the frame rails.
I think I want to move the engine forward an inch or 2. As the current HEI dizzy is very close to the firewall. Is there a problem other than driveshaft issues?
GO GO!!!
Old 03-26-2016, 08:27 PM   #35
Nitis
Nitis's Avatar
Looking Good!!
I probably missed it are you running vortec heads on that? It looks like it has all the holes for your serp setup.
I have all the brackets and maybe all the bolts for one when I get to mine!
Just read it in your other thread vortec heads
Nitis is offline   Reply With Quote
Old 03-26-2016, 09:23 PM   #36
First c10
First c10's Avatar
Originally Posted by Nitis View Post
Looking Good!!
Thanks Nitis,
yes there a pair of ported and polished Vortec heads I did back in 1997 and never used. (house, family, kids etc. you know) with most of the stuff on this engine minus the block from 1996 or 1997.(even found the receipts)
I guess I should have listed what I had for it.
Engine stuff:
Vortec heads
Stainless steel Manley valves
High lift springs
Summit cam comp grind ( not sure the specs I will have to get the cam card)
Double roller timing chain(also had Gear drive but thought that would be a bit much, but love the sound)
Melling high volume oil pump
Performer intake Duel plane for the Vortec heads
Summit magnetic pick up HEI Dizzy.
Hedman long tube headers
Holley 650 Carb
I am sure I am missing something....
The front drive assembly I got from a board member just added the bracket to eliminate the AC compressor.
the system looks good. I just have to alter the PS pump bracket as I am using headers.
I will be posting a few more pictures
GO GO!!!
Old 03-26-2016, 09:27 PM   #37
First c10
First c10's Avatar
Finished up the front accessory drive and installed spark plugs, water temp sensor and a few plugs to get it ready to install.
GO GO!!!
Old 03-27-2016, 03:41 AM   #38
swamp rat
swamp rat's Avatar
I keep thinking maybe i'll do this some day.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-29-2016, 10:32 AM   #39
7dee2
7dee2's Avatar
Nice, is that a chrome pan as well?
Brett
Old 03-30-2016, 12:20 AM   #40
First c10
First c10's Avatar
Yes I tried not to buy anything I already had. Hope the chrome will not rust out fast.
GO GO!!!
Old 04-07-2016, 01:36 AM   #41
First c10
First c10's Avatar
So my son wanted to drive the truck before we pulled it apart for the heart transplant. So this morning he pumped the gas pedal and pulled the choke. Turned the key and BOOM! A very very loud back fire. I went outside and this is what the muffler looked like. Not a clear picture but the dark part is where the muffler split at the seam. He said "I only pumped the gas pedal twice" yeah right!!!
Now it sounds like destruction derby car!,, hahaha
GO GO!!!
Old 04-07-2016, 11:09 PM   #42
7dee2
7dee2's Avatar
Probably scared the crap out of the neighbors!
Brett
Old 04-08-2016, 12:10 AM   #43
First c10
First c10's Avatar
I am sure. As it made me jump and run outside. Haha.
GO GO!!!
Old 04-10-2016, 01:20 AM   #44
swamp rat
swamp rat's Avatar
What? No Banana in the tail pipe??
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-10-2016, 11:26 AM   #45
First c10
First c10's Avatar
Didn't see any bananas. But a lot of loose bolts and dirt packed in every nook and crannie of the running gear.
More pictures to come, as yesterday we disassembled the front end and pulled the motor/trans/tcase. The truck is atleast 2" higher in the front after removing the all cast iron running gear. I bet it is half the weight of the truck.
GO GO!!!
Old 04-11-2016, 02:32 PM   #46
First c10
First c10's Avatar
Here are some pictures of the mess I made.... I started in the back and rebuilt the drum brakes and replaced the bearings and seals. While I was doing this I had my sons removing the front sheet metal ready for removal. Since I had some help I didn't stop to take any pictures...
GO GO!!!
Old 04-11-2016, 02:37 PM   #47
First c10
First c10's Avatar
Here is the picture of the interior after I ripped out the steering column and working on removing the clutch pedal and accessories.
I am ordering new bushings and u bolts so I will be getting the dash replaced with the Tach dash I acquired.
GO GO!!!
Old 04-12-2016, 12:22 AM   #48
swamp rat
swamp rat's Avatar
Guess that little Bang was the starting gun and your off to the races now!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-12-2016, 11:25 AM   #49
7dee2
7dee2's Avatar
Yeah man, BOOM! And not just the muffler!
Brett
Old 04-13-2016, 10:05 PM   #50
First c10
First c10's Avatar
Decided to get the front axle and suspension out of the way so I could check out the frame and get the brake lines bent up. Like anything 48 years old I found a broken rivet on the front cross member and replaces the front driver leaf spring perch bolts with 7/16 grade 8 bolts washers and top lock nuts. As someone used 3/8".
GO GO!!!
